Prop balance
Did the shop also confirm or set the pitch of both blades in that price? Even with that, the price seems way out of line. I would have checked everything I could have before doing the prop balance, like checking the pitch as outlined by Van's procedure. Not sure but there is a possibility the dynamic balance could be good and the blades not equally pitched. Anyway,springs are a highly stressed part and subject to vibrations . Cars use " shock absorbers" , really spring dampers , to prevent springs from vibrating. Not making excuses for the manufacturer,but there are many factors involved, some of them owner induced. The most likely time for any part to fail is when new, infant mortality. Breaking a $14 spring is not the end of the world,aggravating yes. If that spring was on a C172 it would be$50.
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @305
Dues paid 2020
