  #11
Old 07-19-2016, 01:19 PM
Raymo's Avatar
Raymo Raymo is offline
Looks like you have about the same space as my -7. Backup batteries are on the panel supports that come from the firewall back.
Ray
Old 07-19-2016, 02:03 PM
jchang10 jchang10 is offline
One thing that frustrates me is that I wish there were an easier to way to stack boxes on top of each other. Think NYC buildings vs. Montana. It would save some space. I did my best and stacked a few items, but the manufacturers do not make this easy on us with connectors here or there and different box sizes, even within the same manufacturer.
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 07-19-2016, 04:24 PM
jwilbur jwilbur is offline
I just went through this process. If Dynon positioned the D connectors facing up it would make the placement a whole lot easier. In fact for two of the connectors I'll be using a 90 degree D-sub adapter. Assume you're going to need 4 or 5 inches out from the connectors for the harnesses to fit. The 9-pin connectors require a little less. Very annoying.
I can't vouch for these 90 degree adapters yet. I just ordered two of them the other day.
25-pin example:
https://www.amazon.com/L-com-Right-A...t+angle+exit+1
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 07-22-2016, 08:04 AM
Cbull's Avatar
Cbull Cbull is offline
Curious to see how those 90's work, should be just fine.
Thanks for al the tips. I think I will try to make some AL plates and perhaps stack some of the components. Somewhat like the Dynon ADAHRS stacking plate that Dynon issued after I built the tray in the back for mine.
Any time I need to work behind the panel I'll just pull a screen, should be a big enough hole to work on just about anything on the sub panel.
Cory Bull
Lakeway, TX
RV-10 , Interior done, Engine and avionics remain.
Planning on (3)10" Dynon HDX, Garmin GTN 650 and PS Engineering Audio.
2017 Dues Happily Paid
Old 07-24-2016, 10:52 AM
WrightsRV7 WrightsRV7 is offline
Default net adapter location
Like your new design, I put txpder in back too, keeps antenna cable short and isolates antenna from COMs and ADSB antenna, the latter for me is going to bottom center just behind fire wall a few inches. I am putting 5-place net center off right F-1045, using space otherwise going to "waste". I decided to mount ADAHRS up front on bracket, using remote magnet sensor. This seems to save on 1/4" pitot/static/AOA lines for my install (I have steam gauge airspeed panel). The GTN-650 penetrates F1068 if you install above F-1003B, I have cut hole for that with support, angle on the bottom with rubber on F-1068. I am going with one remote/stand by PC680 battery on firewall so I can use it for starting too, if needed. Also using veneer/cables, flown a lot of quadrant equipped singles/twins and sure like the veneer for mixture/prop fine tuning. So makes it a bit easier to route control cables. Quads look cool, but to me, much less functional in the cockpit, just a personal choice we all make (and its cool we can!!). Sure loved the Dynon setup in the RV7, looking forward to many many hours in the RV-10 with their flawless performance!
