07-19-2016, 11:33 PM
Window Trim Jig
I've taken so many ideas from this forum but really haven't given back. So here goes:
I think this only relates to RV-10's, why I'm posting here. I don't really know what builders do for the junction where the windows meet the fiberglass on the inside. Here is my solution, sorry if its been done before.
For this example I used 1/4" deep #8507K14 rubber edge trim from McMaster Carr. I basically made a little jig to cut one side off of the edge trim. To cut the trim I generously applied WD-40 to the trim as I pull it through the cutter. 20' of window trim in 2 minutes, perfectly cut.
I used the 3M instant adhesive in the pic below and installed about 3" at a time. The super glue is very expensive, $30 for that little bottle, but wow does it hold. I haven't even put a dent in it with almost all my trim installed.
A picture is worth a thousand words, so here are roughly 7000 words:
Inside of window....
Outside looking in...
Hope this finds someone who needed it
Cory Bull
Cory Bull
Lakeway, TX
RV-10 , Interior done, Engine and avionics remain.
Planning on (3)10" Dynon HDX, Garmin GTN 650 and PS Engineering Audio.
2017 Dues Happily Paid
07-20-2016, 06:28 AM
That looks great! I will be stealing that idea when I start my interior. Thanks for sharing.
Jason McKay
RV-10
07-20-2016, 07:45 AM
Looks great! So the Scotch Weld is safe around plexiglass? I know superglue will cause issues so when you referenced superglue it made me nervous.
Lynn
RV-10 in Process
07-20-2016, 08:19 AM
Lynn
I glued the trim to the fiberglass and not the plexi. It doesn't take very much to make it hold.
Cory Bull
Lakeway, TX
07-20-2016, 01:36 PM
Looks FANTASTIC! That is an area that is difficult to get to that "automotive quality" level of finish, and you solution looks great.
The Aerosport headliner shells do a good job for the back seats, but I might steal this idea for the front windows
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving -- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
07-20-2016, 01:45 PM
Bookmarked!
...along with a million other links. You guys make the task of building a -10 more difficult by increasing the size of the elephant and the resultant number of bites required to eat him. But that's a good thing, because I'm going for quality and comfort this time around, and the RV bar has been raised in wonderful ways in the last 20 years that I've been a flyer vs. a repeat offender
Thanks for posting this. If Ed K. likes it, I know I want it.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
07-20-2016, 03:49 PM
Thanks fellas. Ed, it's that "automotive finish" that makes the -10 such a great and tedious project. I have so many hours of fiberglass and finish work that were not part of the plans. Many of the projects got shelved, but the experience and knowledge is priceless. I plan to be a repeat offender, but next time something with 2 seats that requires a parachute while I go loop-de-loop. That one will be more militarized in finish...perhaps a -8 or a -14. Hmmmm, better get this one done first.
Cory
Cory Bull
Lakeway, TX
07-21-2016, 10:06 AM
That looks fantastic, I fear the quality of my fiberglass work and hope this will hide some of my miss steps a bit.
07-22-2016, 08:38 AM
That a good idea.... I've caught with that and ended up doing a nice bead of black silicone there... Took a lot of work to get it it right. I might pull it off at some point and try that....
Thank goodness for McMaster Carr, that place is a blessing.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system!
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
07-22-2016, 08:57 AM
LOVE IT
PONDERING THIS ISSUE FOR A WHILE.. YOU MADE MY DAY..IM GOING TO DO IT!
Craig Rufi
FLYING NOW AFTER 13+ YEARS. NICE FLYING AIRCRAFT!!
RV-10/Empennage/Wings/QB Fuselage/Wiring/Doors done finally, Cowling done. Stein panel complete, and connecting all those wires :-))Thousand Oaks, Ca. Dues paid for 2019
