  #11
Old 07-13-2016, 05:18 AM
lShadowl's Avatar
lShadowl lShadowl is offline
Originally Posted by StuBob View Post
Might've been a much different story in an RV-4 or -8!
Ouff, that's true! Gives me chills.
Martin Richer - Mirabel, Qu?bec
www.projetrv7.com
Progression...
Preview plans in hands
Empennage... 90%
Wings... 1%
Old 07-13-2016, 06:54 AM
Low Pass's Avatar
Low Pass Low Pass is online now
I know first hand of a near choking event in a light plane. Only one aboard for the event I know of. Tandem or side by side no factor there. Made me think a little more bit about eating in the plane. Interesting, it seems I now know of two seriously potential events from choking/eating in a plane. But know of zero from pilot incapacitation, as related to an FAA medical certification... Clearly the FAA should make more rules!! How about mandatory placards in the cockpit - "Food Free Zone."
Bryan
Houston
Old 07-28-2016, 11:21 AM
schone schone is offline
Originally Posted by RyanS View Post
3. Keep on a radio frequency that can best help you in an emergency. If it’s an option, consider keeping 121.5 dialed in on your #2 radio.
Most airlines keep 121.5 tuned in and active on the 2nd radio while in cruise. It's great in case you need to transmit on it, but it's also very helpful if you miss a frequency change and haven't noticed you're in the abyss with no one talking to you, since ATC at some point will transmit on that to try to find you. (This obi relates mostly to IFR flights).
Unfortunately a lot of airline pilots are so bored they have nothing better to do than be 'guard police' but whatever... to each their own.
Anyways, if you have a 2nd radio and you can tune to it. I can't see much better uses than activating a listening on 121.5 just while you have nothing better to do.
