07-11-2016, 06:44 AM
Designated FAA Examiner sought for IFR checkride
Looking...
After years of stutter-starts and stops, and plenty of training, I decided to get my IFR ticket.
I'm now ready for the check ride and my local designated examiner informed me I cannot use my RV-4 for the test.
That is a major setback.
Does anyone know of a Designated examiner that would be willing to test me in an RV-4?
Daddyman
07-11-2016, 10:49 AM
Do you mean that he declined, as is his right, to fly in an EAB? Or did he mean that your airplane was not sufficiently equipped for the checkride?
At least you have an examiner. Here in the SFO bay area, they are all booked thru the summer. Too few examiners, plus confusion over the new primary checkride standards (ACS vs PTS).
07-11-2016, 12:23 PM
I suspect that you'll have difficulties finding any examiner that will fly in the tandem RVs. They are going to want full instrumentation and controls. Most RV-4s that I've seen only have a stick, if that.
You may want to go find a DA-20 to rent that has a similar panel as yours. I've found the stick to work relatively responsive as my RV-10, it just flies quite a bit slower.
07-11-2016, 03:07 PM
unqualified unfluencer
Call John....
The guy who did my IFR checkride in my RV-6: http://www.vansairforce.net/articles..._checkride.htm
He lives in Iowa (not THAT far from VA)
v/r,
dr
Doug Reeves (your host) - Full time: VansAirForce.net since '07 (started it in '96).
- Part time: Supporting Crew Member CAE Embraer Phenom 300 (E55P) @ KDFW.
- Occasionally: Contract pilot (resume).
07-12-2016, 12:05 PM
YEs he did have the right to refuse
My plane has passed an IFR pitot, static, encoder and altimeter.
It does have IRF flight instrumentation.
Daddyman
07-12-2016, 12:07 PM
thanks for the tip
Thanks for your suggestion.
One of my hanger buddies, just rented one to complete his check although he owns a beautiful RV-8.
Daddyman
07-12-2016, 01:04 PM
Could it be that the DPE doesn't want to do it because it's tandem seating? I can imagine the DPE having a hard time seeing the instruments from the backseat to determine how well you're flying the needles.
Aaron Sims
RV-10 (2015 Bronze Lindy)
RV-6A (sold)
Home Field: Mallards Landing (GA04)
Locust Grove, GA
07-12-2016, 01:23 PM
I wouldn't expect any examiner or cfi to allow the person in the front seat to be "under the hood" while they were sitting in the back seat.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
07-12-2016, 04:21 PM
Hi David, This might or might not help. Its all kinda run together, but "Carl" is answering "me", starting with "I've seen IFR---"
Originally Posted by donaziza View Post
OK, respectfully to the RV community, (not to be a wise guy), I've got just the reverse problem. I've got thousands of hard IFR hours, but its been 13 years since I did any of it. And then I've got an 8 vs a side by side. If I can get my financial act together, I want to put a GRT EFIS cockpit in my plane. Short of getting a very tall CFI in the back seat, and pulling out my "booster" pillows (I'm very short waisted), and sitting as low as I can in the front seat, I can't see any alternative to renting a spam can.
I've seen IFR bi-annuals done in an RV-8 - the CFII in the back had an iPad with wifi to the Dynon system. Of note the CFII was an RV-8 builder and owner. So - go find one near you.
Carl
And one more from Carl,
I did not know that Carl. Would that trick also work with a GRT setup? Or just Dynon?
Don't know - but GTR advertizes an Android app that lets the rear seat guy get a repeat of the GTR display on a tablet via Bluetooth. That should do the trick.
Carl
07-12-2016, 04:44 PM
Daddyman
Do you have enough different forms of navigation? GPS alone is not enough to take the test.
