07-05-2016, 09:13 PM
first time new brake pads, 450 hrs
nothing special. it was an easy job.
check brake pad wear, lowest measurement was at the corner of the inner pad, .110. limit .10, so I was almost there.
no need to remove the wheel or open the brake line for brake pad check or replacement if brake line can flex.
ok, while at it, removed the wheel for bearing grease.
pack bearing
flight checked good. an easy job. brake pads, $33 total. can't beat the price.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
07-05-2016, 11:52 PM
Beats the heck out of rebuilt King air brakes at 3k per side.
Actual repeat offender.
07-06-2016, 09:46 AM
I'm on the same replacement interval as Steve ... My pads at 270hrs showed very little wear, maybe not even halfway. I suspect they'll be ready for the scrap barrel at 450.
( I wish I could say the same for my tire wear issue on the L side.  )
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
07-06-2016, 02:06 PM
It's great to know that pads can last that long (technique-dependent, of course). I'm always letting her roll an extra taxiway on landing so I don't have to stomp so hard!
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
07-06-2016, 02:37 PM
Try a bunch of right aileron on takeoff. That has evened out my tire wear considerably.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
07-06-2016, 03:10 PM
you're joking..... right?
Steve Melton
Cincinnati, OH
07-06-2016, 03:27 PM
No I suspect he is serious. I have noticed how aileron can load one wheel or the other and cause more drag on each side depending on where you hold the stick.
07-06-2016, 06:24 PM
Not at all. Torque on takeoff is trying to rotate your airplane towards the left main gear, which loads up that tire a fair amount. With that in mind, you're gonna chew up the left tire faster than the right one. Add in any side load and it gets worse. Aileron mitigates some of this...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
07-06-2016, 08:45 PM
that's something I had not considered. my engine = 160 HP, at 2700 rpm = 312 ft-lb torque. with about 3 ft from the crank center line to left wheel results in 104 extra lbs on the left during takeoff. I'll tell my wife to have another piece of pie.
Steve Melton
Cincinnati, OH
