07-05-2016, 06:10 PM
Throttle hanging up...
...CT 82F DELUXE QUADRANT.
Of late my throttle has been hanging up, not stuck, just difficult to move. Releasing the locking knob had no effect.
In checking the thing over, I found the throttle lever is binding in the top surface slot it resides in. I lubed the slot and lever and it moves much better.
In looking at a photo of CT 82F in Vans catalog, the lever is not in the slot, it is outside the slot on the outboard side. (?)
I am wondering if I installed the device correctly.
It is the same set up with CT83F, the 3 lever deal for CS prop. That photo also shows the throttle lever out side the slotted piece and not in the slot.
How have you installed your CT82 or CT83 throttle lever. Is it in the slot on the piece with lettering or outboard of the top piece?
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
07-05-2016, 06:23 PM
David, that picture in Vans catalog is kind of deceiving. If you enlarge the picture you will see the throttle arm is in the slot not outside of it.
Bill
RV-8
07-05-2016, 08:01 PM
Well thanks for doing that, Bill.
I will continue the mission and not think about it any more, the throttle is working fine with a little white silicone grease in the slot.
RV-12 Build Helper
RV-7A...Sold #70374
07-05-2016, 08:54 PM
Sure sounds like a throttle cable is failing. Get stiffer and finally hang completely or break.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
 I just wish I could afford to live the way I do
07-05-2016, 08:55 PM
VAF Moderator / Line Boy
Just what I was thinking - and I speak from experience.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
07-06-2016, 02:29 AM
Thanks for that observation.
It is almost new with 125 hours but will check it.
RV-12 Build Helper
RV-7A...Sold #70374
07-06-2016, 08:37 AM
Throttle Cable
I have replaced my Throttle Cable twice because it got hard to move. It is because it passes close to the exhaust pipe as it gets close to the bracket holding it before it connects to the Fuel Servo (FI). The heat from the pipe melts the lining in the cable. I have fire sleeve on the cable and a heat deflector, but over time it still gets hard to move. Same with Mixture Cable.
Stu McCurdy (Falcon)
RV-8, 78TX, Flying
Formation Flying, Inc (FFI)
Falcon Flight
07-06-2016, 09:29 AM
Proceedure for stuck throttle?
OK, I have to ask,
What is the best procedure for loss of engine throttle in cruise or descent assuming your power setting is high enough to sustain flight?
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
07-06-2016, 11:10 AM
I've replaced the prop control for the reasons Stu mentioned.
Use the mixture if prop is stuck open or close to open. It'll run rough when you reduce power (very lean) but you'll have instant power when you need it.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
07-06-2016, 02:00 PM
Originally Posted by jdeas
OK, I have to ask,
Simple - cable doesn't go from "working fine" to "stuck tight" in one flight. You get plenty of warning, so listen to your plane talking to you. When something doesn't work right, fix it before leaving the ground, and you'll minimize the excitement.
Oh yeah - mixture can be used in an emergency.
Paul F. Dye
