Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #11
Old 06-30-2016, 05:00 PM
BD4Guy BD4Guy is offline
Default Bump
Bump for this fascinating thread.!
Donated 2013.
Old 07-04-2016, 01:14 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Here's a photo of Dave's SDS installation along with the magic TB scoop. Inside the scoop is a tight fitting, large diameter, velocity stack which clamps to the TB snout.
Another update from Dave after some more flying:
"I have always let guys see what I’ve done if they were interested. Over the years i have just continued looking for practical applications of sound theory. Decreasing drag is more effective than increasing HP. It gets increasingly more difficult to find performance gains as you continue working. All the easy ones are already done and then even when you do something you know is sound science sometimes, it isn’t easy to prove it worked. I have made over 30 changes to my plane and some took perhaps 3-4 small changes together to be able to see any improvement.
I like the experimenting and then testing. I can already tell that the better atomization the SDS provides for the mixture at high altitude is so far superior to the old system I had, and the improvement in runway acceleration and climb is obvious, let alone the ease of operation. It just makes sense to get the maximum pwr out of the fuel you’re using. I had to call off my test yesterday when I saw the fuel leak between my legs at 17500’ but I’ll get that corrected and continue testing. (Seeping pipe plug fitting on pump module)
I’m really anxious to be able to peak each cylinder to see how far apart they are from each other at max pwr WOT and compare it to low power economy high alt cruise. As I’ve said, the CHT spread is smaller than ever before and I haven’t even been able to try tuning each cylinder yet."
Dave has done some more tests on moving the injector thermocouple to other injectors to see what differences are present. He's compiling data on that now.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 07-04-2016, 04:08 PM
Toobuilder's Avatar
Ross,
Any interest from Dave to try your new direct port injectors? As much as he likes to tinker, it seems a natural upgrade to aim the nozzle discharge right at the intake valve instead of the tube mounted setup.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 07-04-2016, 04:26 PM
rv6ejguy's Avatar
Originally Posted by Toobuilder View Post
Ross,
He hasn't said much yet about it. He spent several months getting the new engine and EFI installed. Now that it's all together, I think he wants to have everything well tested and tweaked before he heads to Reno in September. Beware other RV class entries. This thing is wicked fast.
That being said, since we do have an angle valve, top mount injector solution now, it would be interesting to have Dave test them back to back after having a good baseline with the tube mounted setup.
In race car stuff, it's been found that the injector being placed further from the port actually makes a bit more power than right in the port on most engines. Throttle response and cold starting is usually a bit worse though.
Old 07-04-2016, 04:29 PM
BillL BillL is online now
Default Love looking under the "hood"
Like the exit chute w/side guides. I can't quite figure out the oil cooler exit? One day would be interested to see what he does under that plenum for cylinder and head shrouding and air flow management.
Thanks Ross. Thank Dave for us.
Bill
RV-7
Lord Kelvin:
Old 07-04-2016, 05:07 PM
rv6ejguy's Avatar
Dave sends me photos and test updates often. I have some more photos I can post here tomorrow if I get time, showing some different angles.
Airflow management in the cooling system is important for drag reduction and I know many people on VAF are interested in real world testing like Dave does.
Remember he's also cooling more hp than most other folks with similar sized engines.
Old 07-04-2016, 05:25 PM
DanH's Avatar
DanH DanH is online now
No magic there, just the optimization Dave talks about. I think he has been running the basic concept (a diffuser teamed with a velocity stack) quite a while. Downside is running filterless all the time.
Dave has been doing that a long time too. He is not the only one.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-04-2016, 06:05 PM
rv6ejguy's Avatar
The latest iteration is much better than his last design and filter use is not important for Dave's mission or engine situation which is almost strictly about best performance possible.
I use the word "magic" loosely to describe stuff which works better than what most folks are doing in whatever field is involved. Dave's been doing this stuff a long time as you point out, so is a pioneer here in many ways. It's easy to copy, harder to innovate. Few others can match his accomplishments with an RV.
Old 07-04-2016, 06:25 PM
Default side chutes
Yes, I know, you have some too, Bob Axsom did some, pretty standard for good exit collection . . . . not radical though . . . . I still like 'em
I downloaded a presentation by Dave posted in a local EAA meeting from a while back ( could have been 2000) , too bad the pictures were not along with the text. It seems he added these in 1995.
Bill
RV-7
Lord Kelvin:
Old 07-05-2016, 08:55 AM
rv6ejguy's Avatar
Default Couple more photos
