Go Back   VAF Forums > Model Specific > RV-6/6A
Old 06-30-2016, 07:47 PM
Gizmos Gizmos is offline
Default Change from tilt up to slider?
Has anyone changed a tilt up to a slider? If so, photos,material list I need to order,..any help? Thanks
I am building my rv9a and I got the rv6 that the canopy was installed bad. If I got to change the canopy, I would like to make it a slider. The plane is under construction so now is the time
Old 07-01-2016, 09:00 AM
rvbuilder2002's Avatar
This change is possible but it would require replacing all parts on the fwd fuselage that are above the main longerons, and replacing the fwd top turtle deck skin.
Then obtain all of the sliding canopy parts, and basically start over.
The fwd portion of the tip-up canopy could possibly used as the windscreen portion of the slider if you could source just the aft half (purchase one with a broken front, etc.)
Scott McDaniels
Hubbard, Oregon
Old 07-01-2016, 09:16 AM
N941WR's Avatar
N941WR N941WR is offline
Scott, would you also have to replace the top, aft skin as well?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-01-2016, 09:24 AM
Yes he would.......
The turtle deck is the top of the tail cone, but only the fwd of the two skins would need to change.
Scott McDaniels
Hubbard, Oregon
Old 07-01-2016, 09:35 AM
N941WR's Avatar
Yes he would.......
Sorry, I saw "fwd" and was thinking forward of the cockpit.
Bill R.
SC86 - Easley, SC
Old 07-01-2016, 06:24 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
My next door hangar neighbor converted his tip-up RV6 into a slider over last winter. It was a lot of work but he's pleased with the results and thinks it was well worth the effort now that we're about to hit triple digit summer heat here in north Texas.
Neal Howard
Airplaneless once again...
