I have no affiliation with the company or anything.
POSITION AVAILABLE: PILOT
An ISBAO registered, 14 CFR, Part 91 corporate operator in the Dominican Republic, operating "N" registered aircraft, is seeking one full time pilot for its fixed-wing and rotor-wing fleet. See minimum and preferred qualifications for more detail.
Initially, the position will be Line First Officer (SIC) Fixed-Wing with the ability to upgrade to Line Captain (PIC) in a time period based on previous experience and successful completion of initial operating experience.
The position is based along the Southern Coast of the Dominican Republic.
Salary and benefits commensurate with experience. Details of packages will be reviewed in more detail with final candidates.
Qualified candidates should send their r?sum? to
hiring@crcaviation.com.
Job Requirements
The Line First Officer/Second in Command (SIC) will assist the Line Captain (PIC) in the management of an assigned flight and will carry out duties as assigned by the PIC. The Line First Officer/Second in Command (PIC) reports to the Line Captain during the assigned flight operation.
a. Assisting the Line Captain with discharging operational and safety responsibilities
b. Providing excellent customer service to passengers
c. Actively participates in the Safety Management System (SMS)
d. Performing duties as assigned during flight preparation and in flight
e. Being prepared to assume the duties of the Line Captain in the event the he becomes incapacitated
f. Ensuring assigned flight is conducted safely and in compliance with all applicable FAA, IDAC, ICAO, and host country requirements, and within the aircraft manufacturer's limitations
g. Other duties as assigned by the Line Captain
Minimum Qualifications
Ability to Obtain FAA Type Rating in Company Aircraft Upon Hire (Company Provided)
FAA Commercial Fixed-Wing
2,500 Hours Total Time: 1,500 Hours Must be Fixed-Wing
500 Hours Total PIC
750 Hours Total Turbine Time: 250 Hours Must be Multi-Engine Jet (No Centerline Thrust Time Accepted)
Preferred Qualifications
FAA ATP Fixed-Wing
FAA Commercial Rotor-Wing
3,000 Hours Total Time: 2,500 Fixed-Wing / 500 Hours Rotor-Wing
1,000 Pilot In Command in Turbine Fixed-Wing
500 Hours Total Time in Turbine Rotor-Wing
