Old 06-25-2016, 08:03 PM
TrickRacer50 TrickRacer50 is offline
Default Insurance During Building?
Hi All!
Soon I will add some expensive parts to continue building my RV10. What is the best type of insurance to get to cover the cost of parts in case of fire, theft, or damage?
Van's website says homeowners insurance will not cover the parts. I still need to check on my personal policy.
What are others doing to protect their investment?
Sean Mecham
RV-10: VS, Rudder, HS, Elevator, Tailcone - Complete
Prepairing to Order Slow Build Fuselage
Vancouver, WA - Pearson Airport KVUO
Member of FATPNW
Old 06-25-2016, 08:09 PM
majuro15's Avatar
majuro15 majuro15 is offline
I did a builders risk policy through USAA who I believe uses Starr Insurance. Do a search for builders risk, lots of info out here on VAF.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
Old 06-25-2016, 08:10 PM
Vansconvert Vansconvert is offline
Default Ground not in motion
I suggest you look into a policy called Ground Not In Motion. So, if it is in a hangar and the hangar blows over, you are covered. If your hangar catches on fire and as a result all the hangars catch on fire, your stuff is covered. Your hangar neighbors might be covered if you have liability insurance on top of that.
I could not get just ground in motion, my policy had to have the liability insurance as well, due to the example stated above, and similar scenarios.
RV-7A
IO-360 Hartzell CSP
Purchased
Old 06-25-2016, 08:11 PM
RV-7A
IO-360 Hartzell CSP
Purchased
Old 06-25-2016, 09:00 PM
DaleB's Avatar
DaleB DaleB is offline
I called our friendly Arthur Gallagher people and got a builders insurance policy. Cost me about 250 bucks for a year. It covered all of my parts whether they were at my house, at a hangar, in a storage unit, or in transit.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 06-25-2016, 09:13 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I have USAA on everything, when I spoke with them, they were very certain that any type of airplane parts or even tools, were NOT covered, and suggested I contact aircraft insurance companies for the "builders insurance" I was seeking.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 06-25-2016, 10:45 PM
awmuhs's Avatar
awmuhs awmuhs is offline
Default Gallagher Ins
Ditto on Gallagher for me
Alan Muhs
Tucson, Arizona
Dues overpaid July 2020
RV12iS Southern Arizona Teen Aviation: #1 airplane sold, #2 airplane working on engine/finish kit, #3 airplane tail kit finished.
RV10 flying since July 2014- 700 hrs as of July 2020
RV6A sold after 500 hours of flying
Old 06-25-2016, 10:55 PM
greghughespdx's Avatar
Yeah, call Shanna Linton at Gallagher - advertiser here on VAF. She/they are great!
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
Old 06-25-2016, 10:59 PM
Thanks!! I will check that out...I am building at home. I will also try the other search options.
Thanks!
Sean Mecham
Member of FATPNW
Old 06-27-2016, 06:04 AM
majuro15's Avatar
Mine is actually insured by Global Aerospace. I still got it through USAA, just call them up. It shows up online under My USAA, so makes it pretty easy. You just name the value you want covered, pretty quick and simple. Very comprehensive.
www.N1017H.com
PC-12 Pilot
EAA #: 1106970
2020 VAF Dues Paid!
