04-18-2016, 12:01 PM
Super Moderator
My opinion
I don't think the unsecured red plastic caps belong in the engine compartment. If they do fall off and land on the hot exhaust they may start burning and cause excitement in the cockpit, or worse. They are for shipping purposes.
Vic
 Vic Syracuse
www.Baselegaviation.com
04-18-2016, 05:53 PM
VAF Moderator / Line Boy
I lost one years ago that had been tightened with a set of rounded pliers - it takes nothign to put some safety wire on it to make sure it at least stays onboard if it comes loose. Otherwise, your friends will never let you forget it....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
04-18-2016, 06:07 PM
Super Moderator
Yes.
For the caps that don't have the safety wire hole in them, some Locktite 242 (medium strength) works.
Vic
 Vic Syracuse
04-18-2016, 11:06 PM
Mine had a black rubbery cap, almost as good as red?
Blue Loctite it is, then, there being no safety wire lug on the Vans cap. Thank you all, gentlemen!
Kurt Haller
P-town, CA (10 min from KLVK!)
N748PK, RV-9A
Flying as of 13 July 2019
VAF dues last paid 28 Dec 2019
04-19-2016, 10:40 AM
Vic
Vic,
Got it. Rubber cap is now safety wired! Thanks!
Mike W
Venice, FL
N164WM
04-19-2016, 11:00 AM
Lost Tach Drive Cover with Yellow Tag
Originally Posted by Ironflight
I lost one years ago that had been tightened with a set of rounded pliers - it takes nothing to put some safety wire on it to make sure it at least stays onboard if it comes loose. Otherwise, your friends will never let you forget it....
Are you saying that because one of our friends gave you this for a birthday present back in 2007 after you lost one?
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
06-14-2016, 02:44 PM
Where does one lockwire the cap to? Installed mine this weekend but didn't see a good location to lockwire to.
Empannagee done
Wings 90% done
Received fuselage
06-16-2016, 01:17 PM
If I recall correctly, the 45 deg oil filter adapter had two holes--one filled with the safety wire securing the filter, the other open and a potential anchor point for the tach cap.
If, that is, Van's tach cap was designed for safetying, which it's not.... The blue loctite is holding up so far after 0.0 hours  .
Kurt Haller
N748PK, RV-9A
06-19-2016, 06:14 AM
Andair
I did not see that anyone had mentions that Spruce has the Andair caps. They are very well made and have lots of hole to safety too. A little more $ but not much for what you get out of a good quality unit. Hope this helps, Yours R.E.A. III #80888
