Old 06-09-2016, 02:58 PM
scard's Avatar
scard scard is offline
Default Ground Breaking, shop build starts (Concrete!)
Well, I guess we've finally broken ground on the new shop building. We moved to our new place almost nine months ago so the -8 project has been mothballed. We started planning this building even before we closed on the house. This is something I've always wanted to do. It is going to be 40' x 30', 12' ceilings, fully finished like living space except no "plumbing". There will be a full length 8' wide porch on one side so I can watch my vegetable garden grow. The GC is "TC Construction" and I seem to be the field supervisor. It should be exciting but boy it is amazing how hard it is to get contractors to do work for money.
Image from a raspberry pi attached to the garage doing motion sensing and capturing images for compilation into time lapse for the build.
Scott Card
CMW E-Lift
Old 06-09-2016, 03:09 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Congrats to you----------but ........no plumbing???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-09-2016, 03:15 PM
scard's Avatar
You'll just have to read through the quotes. I can't afford the taxes or the completely re-engineered septic system that would be required and never approved.
Scott Card
CMW E-Lift
Old 06-09-2016, 03:28 PM
Mike S's Avatar
Senior Curmudgeon
AAAAHHHHHAA.
Got it.
Would be a shame if you could not run your air compressor lines
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 06-09-2016, 03:56 PM
bret's Avatar
bret bret is offline
what if there might be something here or there that you had measurements for and maybe at a later time a hammer broke through thin portion of concrete and might have gone to something that was planed but never GOT installed at the time of final inspection?
Old 06-09-2016, 04:08 PM
scard's Avatar
You read quotes quite well kind sir .
Scott Card
CMW E-Lift
Old 06-09-2016, 05:23 PM
Ron B. Ron B. is online now
Just got in from the hangar a few minutes ago giving some US friends a tour. She peeked in the washroom and I said it's the best part of this hangar.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 06-09-2016, 08:34 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Porta-Potty
I have a detached shop I built. Has water but sink drains to the wash on the property. I just use the sink to wash up after a day of airplane building. Bio breaks give me a chance to go into the house and check in with the boss.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 06-09-2016, 09:01 PM
Cyclone Cyclone is offline
Default Shop Plumbing
My shop is five miles from my house. Since the site did not pass a perk test I installed a 1500 gallon holding tank for septic which is pumped every couple of years and the utility sink unofficially drains to a rock bed.
RV12 - Flying August 2019
Restoring 1967 Ford pickup - no amount
of money will make this thing fly.
"I have enough money to last me for the rest of my life.
As long as I don't buy anything"
Old 06-10-2016, 06:23 AM
DanH's Avatar
DanH DanH is offline
Taxes? Texans pay a higher tax rate if the building has indoor plumbing?
Dan Horton
RV-8 SS
Barrett IO-390
