Go Back   VAF Forums > Model Specific > RV-6/6A
Old 06-08-2016, 03:08 AM
Pittsartist Pittsartist is offline
Default Oversize Tyres ?
I operate from a grass strip here in England that is prone to getting soft in the winter months. At the moment my aircraft has completely stock wheels (Cleveland 500x5) and stock Vans wheel fairings.
Looking at G-IKON's build blog
http://gikonfinsh.blogspot.co.uk/200...res.html#links
It seems that 380-x150-5 sized tyres can be made to fit and will help in reducing ground pressure.
Has anyone else done this ?. With an RV-6 or 7 ?. Are the fairings the same ?.
Old 06-08-2016, 04:27 AM
n816kc n816kc is offline
Default Here you go
http://www.vansairforce.com/communit...hwheels+Rocket
http://www.vansairforce.com/communit...ad.php?t=27980
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
Old 06-08-2016, 04:34 AM
I switched tyre (tire) size on my RV-8.
I was fortunate there was sufficient top and back clearance within my wheelpants to accommodate the larger width and diameter. I did need to enlarge the bottom opening.
If your wheel pants do not have enough clearance, then the effort to switch may be considerable for a flying airplane.
There are a number of posts and threads on the subject here on VAF:
https://www.google.com/search?q=site...ce.com+380x150
Old 06-08-2016, 09:44 AM
smokyray's Avatar
smokyray smokyray is offline
Default Big Ones...
Yes sir!
Here's a great thread also listed above, I ran 380's on all my RV's and my HR2 per Steve Sampson's experience. They do require the newer Van's PR wheel pants and a bit of cutting, otherwise a win win...
V/R
Smokey
Old 06-08-2016, 09:55 AM
Jeff Hagg Jeff Hagg is offline
Default Made the Tire Change
I made the 380 change last month, like the fit and feel. Running with out wheel pants at the moment. Since I run with a 0540 I felt the bigger tire would help out.
Old 06-08-2016, 04:14 PM
grubbat's Avatar
grubbat grubbat is offline
Default 380's Tyres
I went with 380's on my -6a and it helped with the rough field work. The wheel fairings had to be enlarged some but not too difficult to handle.
For my current -9 project, I am going with W60 6" wheels from Matco which will work on the standard Van's 1.25" axle, and 8.50x6 backcountry tundra tires. I tried these tires out on a Maule recently and the ride was incredibility smooth. Over the nose visibility will be limited with this setup but no matter as my mission for this -9 is dirt, grass, anthills, potholes, and so forth.
Good luck with your project!
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 06-13-2016, 09:23 PM
BruceMe's Avatar
BruceMe BruceMe is offline
Go big or go home!
http://www.aircraftspruce.com/catalo...er06-02501.php
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 06-14-2016, 04:17 PM
Bevan Bevan is offline
I have the 380x150-5 for mains on my RV7A. They fit the stock vans wheel pants that came with my kit. 500x5 on the nose with RV10 nosewheel fork (machined to fit), and fairing. It rolls around in the hangar with ease.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 06-14-2016, 04:58 PM
jimgreen jimgreen is offline
I mounted the wheel fairings higher during the initial build and after a couple of years fitted the 380 tires. Loved the tires - much easier to roll out of the hangar and manoeuvre on grass.
For me the problem was main gear shimmy. The tires weigh more, and I believe that contributes to the tendency to shimmy. Eventually I gave up and went back to stock tires.
Perhaps I was just unlucky. It took a lot of lead to get good static balance.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
Old 06-14-2016, 05:43 PM
sparkcrafter sparkcrafter is offline
Are there any issues/downsides with using 380's on the main wheels and leaving the stock nose wheel on a 6A? Any effects on takeoffs/landings?
Jerald
