06-03-2016, 08:18 PM
fuel smell in cockpit
On take off and other times I'm getting gas smell. I feel that a little bit of fuel may be coming from the vent tubes on belly and is coming into the cockpit by way of the wing root. Tanks are not leaking, and the vent tubes about 1inch in length are cut for a positive pressure forward. Any ideas to help,rv4
06-03-2016, 09:13 PM
I would check all your fuel line connections from the wing root, through the fuel selector and so forth all the way thru the firewall.
Look for tell tale blue staining.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
06-03-2016, 10:53 PM
I had that faint fuel smell and found a loose nut on the bulkhead fitting under the wing to fuselage fairing. Don't forget the rear bulkhead rivets on your fuel tanks either. John
06-03-2016, 11:47 PM
I occasionally get the same thing. I have inspected thoroughly all connections. They are all secure and no evidence of leaking. It only happens on take off with high angle of attack and with the aux electric pump on. I am interested in others thoughts.
Tony Phillips
N524AP, RV 9 (tail wheel)
06-04-2016, 04:50 AM
Check your carb for staining ,as on my 4, with boost pump on the inline fuel pressure is at the high end for a carb, and can cause slight leakage . This may explain why it's at takeoff and high AOA. I turn my boost off as soon as I hit safe altitude. For the record, I have 2 electric Facet pumps and no mechanical. One runs continuous, and the other is boost.
Bill E.
RV-4/N76WE
8A7 / Advance NC
06-06-2016, 10:02 PM
I used to get fuel smell and it was from leaking around the seals where the fuel sender plates are screwed onto the tanks at the wing roots. Took plates off, got rid of old gaskets (think they may have been cork?), resealed with proseal, no more leaking or fuel smell.
06-07-2016, 12:00 PM
Do you have the float or capacitor system in your tanks? I had a small weeping leak in the center of the connector (NCB ?) that was hard to fine, but pretty easy to fix with pro seal.
06-07-2016, 06:59 PM
Vent line
I just did my annual, and found that the B-nut connecting my vent line inside the cockpit was not tight at all and blue marks on the floor, this explains why climbing to higher altitudes I always smelled fuel.
just something to check out for
06-08-2016, 06:01 PM
Be sure to check around the fuel selecter. I once had a small leak underneath the lever.
06-09-2016, 06:56 AM
Carb or fuel injected?
If you have a marvel carb.... lightly with finger tips try wiggling the bottom half of the body. After a few hundred hours of normal operation, the vibration can and will loosen the float bowl / bottom half of the carb body from the top half. Even if the screws have lock tabs and or lock wires, the threads loosen from vibration wear. It might not leak fuel on the ground but in flight they will, especially in a slip on approach. There is a SB or AD several years old on this. It is easy to check this one at every oil change when the cowl is off.
If injected, after shutdown, the fuel will heat and expand in the small lines that run to the injector bodies. The injectors have ports and fine screens that will vent the fuel & vapors under the cowl. If a shut down was just the right amount of time before start up and take off, and if your cockpit air is from the top side of the cowl, you can get a momentary fuel smell on the take off roll - but that is about the only time it would be noticed.
