05-30-2016, 07:35 PM
How much paint?
I'm looking at trying to paint my 4 soon. For those of you that have done it yourself, about how much paint is required? I'm looking at a simple scheme, likely a solid color for the entire plane with some vinyl accents.
05-30-2016, 07:42 PM
5 gallons of paint for a RV7A
I just painted my 7A and it took 5 gallons of paint. It took a lot of primer and etch primer. I used Nason single stage polyurethane system available at auto part stores and it is the same as aircraft paint but easier to get.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
05-30-2016, 07:49 PM
Steve, about how much primer was required for yours?
05-30-2016, 08:59 PM
I painted my RV-6A in a red and white scheme. I used 1.75 gallons of white and a bit less than 1 gallon of Red single-stage. I probably used a gallon and a quarter of Epoxy primer. I probably used about 1/4-1/2 gallon of clear coat on top of some of the single stage. These do not include activator quantities.
Good luck with your project. Let me know if you need a recommendation for paint. I have a great supplier.
Larry
05-30-2016, 09:08 PM
There are lots of assumptions that go with paint quantity. Single stage or two stage? Conventional or HVLP sprayer? Experienced painter or neophyte?
I was a neophyte and probably used 5 gallons of single stage paint through a conventional gun on my RV-6. I guarantee you that if I'd started right into painting another RV when I finished that one, I could have done it with 3 to 3 1/2 gallons.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
05-30-2016, 09:48 PM
Five gallons is about what I used, 4 colors two primers colors (mixed 10 gallons) then there was three gallons epoxy primer, two gallons clear I used DuPont chromabase, and went through 5 HVLP guns. Over 5K in materials guns, mask, filters ect. three years in the making and it is still just an OK paint job that needs a few runs fixed. lots of arguments about paint smell and stress. but it was fun!
05-30-2016, 11:05 PM
Primer used
I used about 1 gallons of etch primer. It is used with just one thin coat and only on aluminum parts. Not used on fiberglass parts.
I used 4 gallons of sand able primer. Everything got primed with at least two coats.
This does not include the catalyst, reducers, activators, and accelerators.
I used 2 HVLP Devilbiss guns, one for primer one for paint. I followed the spec sheets. I sprayed at 25 psi at gauge which is 10 psi at novel. I waited the designated time between coats. I had a paint both and a lot of overspray went up the filter. I used the DeKups disposable cups and recommend them.
I took the class from Sherwin Williams last summer which I recommend.
My 7A is half white on top and half blue on bottom with a grey stripe in between.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
05-31-2016, 08:26 AM
I used all PPG products (base and clear coat)
For the RV-8A:
- 1 gallon PPG-DP40LF primer (this was after all the fiberglass pinhole fill, prime, sand, repeat was done). One coat and apply first base coat as soon as allowed.
- 1.5 gallons of base yellow (two coats)
- 1.5 gallons of pearl on top of the yellow (tri coat color) (two coats)
- 1 gallon of metallic blue (base coat) (bottom of plane, wheel pants, wingtips and trim) (two coats)
- 1.5 gallon of urethane clear (two coats)
- 4 gallons of temperature appropriate reducer
- A boatload of Fineline tape and masking paper
For the RV-10 more than double the paint - and ten times harder. I had a lot of rework to do. Next time I'll get help.
Keep track of your times.
Carl
05-31-2016, 10:14 AM
You took the Sherwin Williams class but used Nason paint.
Was there a reason for not using the S-W products?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
06-01-2016, 05:34 AM
What I did
I painted my -4, Single color, PPG Desothane White (Airliner paint) which is single stage Urethane. I got mine in a 4 gallon kit (3 parts and reducer), and when done I had about a half gallon left over. I painted with all flt controls off, so paint covers every bit of the aircraft. I used PPG Dp-40 primer (thin coat) and 3 coats of the Desothane top coat. Because I got my paint "donated" from a project at my day job, I only had to buy the primer...so, I have $300.00 total dollars in my paint job. Glad I did it myself!
Bill E.
RV-4/N76WE
8A7 / Advance NC
