05-26-2016, 09:13 AM
Removable floors, nut plates between front seat floor and foot wells?
I've decided to make my floor removable. For others that made their floors removable did you rivet the foot wells(F-829B) to the front seat floor(F-829A-1) or is there enough flex in the floor to get the whole assembly out?
05-26-2016, 09:36 AM
RV-8 floor
If you build per the plans (I did) the two foot wells and the small floor section riveted together are easily installed/removed but do require some flexing and are not just a drop-in. If they were riveted to the two large floor pieces farther aft they'd be impossible to remove (I think). I riveted the two main floor pieces (mid and aft cabin) down too early - before drilling for the flap stop/fairing! Rats. Much to my surprise it took less than 10 minutes to drill out the pop rivets and remove the floors. After doing drilling and install of the flap stops/fairings it took less than 10 minutes to put the floors back in and rivet them with an inexpensive HF pneumatic pop riveter. I believe doing the nut plate screw route would: a) take a lot of time, material and work; b) weigh more; c) take longer to remove and install than the pop rivets. Hopefully you'll get other opinions which will help you decide. In my case I found little under the floors I couldn't secure adequate access to from forward and aft openings.Good luck!
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
05-26-2016, 12:08 PM
After thought
I too assembled the front floor pan/foot wells as per the drawings and it does take a bit of flexing to get it in and out. If you have painted interior you will have be extra careful not to scratch it. If I where doing it again I would attach at least one of the foot wells to the floor pan with screws and nut plates just to make it a bit easier...might even make this modification next time I remove the floor pan. food for thought.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2020
05-26-2016, 12:10 PM
I've already done the work, added the weight, etc. It's just the foot wells to forward floor I'm wondering about, but if you can get them in and out I should be good. Thanks!
05-26-2016, 12:57 PM
Thanks for update. I didn't realize you had already done all that work! Bet it looks great, "customized."
Bill Dicus
05-27-2016, 11:40 AM
Mine is built per the plans and I'm thinking about doing the mod to make the rear sections removable as well. I'm starting to think about all the wiring and such that needs to be put in when I upgrade my panel, would make life a lot easier if they were removable.
Brant Seghetti
Top Cover Aviation
Nut Tree, CA
P-51, RV-8, 90A, S1
ATP, A&P, IA
Dues Gladly Paid
05-29-2016, 07:42 PM
Removable aft floor panels
Ok guys. Just a opinion from an early builder that has removed his floors for an autopilot upgrade. Do not deviate from the plans. Everything is just fine as designed. The rear floor panels can be easily removed in much less time than unscrewing all those steel screws. Just use your drill and a long 1/8 drill bit. If you install all the nut plates you will get more weight, more expense, wasted time, and a sore back with no real gain. There is a good chance that you will twist out the head of one of the screws and then you will be drilling out a steel screw instead of a soft aluminum rivet. The soft rivets can be drilled out in a matter of minutes. The only thing that slows you down is removing the rivet heads from your drill bit.
Danny King
Beautiful Doll 80434 TT 1675 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2020
05-29-2016, 07:51 PM
I agree with Danny. I put rivets in mine and would do the same if I built another one. Drilling out a pop rivet is no a big deal.
Christer
Director of Maintenance, SteinAir Inc.
RV-8 Completed
05-29-2016, 09:09 PM
RV-8 Floor Panels
When building my RV-8 and when it was in the canoe stage, I decided to put nut plates in for the whole floor, front and back. I wanted to get under the floor for whatever reason.......fluid spills, new wiring, components, etc. Happy I did. Easy to install components when I needed to.
Stu McCurdy (Falcon)
RV-8, 78TX, Flying
Formation Flying, Inc (FFI)
Falcon Flight
03-12-2020, 11:34 AM
I am reviving this old thread to ask new question.
Given the stock market is tanking, I can't cash out some of my stocks to get a Vans engine and prop so I decide I can use this extra wait time for the stock to recover to finish up my fuselage. With regard to installing the floor nutplates, do you install the nutplates in the all places call out for the LP4 pop rivets?
Thanks in advance.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
