Old 05-24-2016, 12:07 PM
AllThumbs's Avatar
AllThumbs AllThumbs is offline
Default New trim tab for new rudder
We (actually, my plane partner Ralph) rebuilt our RV-6 rudder when the old .016 rudder developed too many cracks. We've taped on a temp trim tab and are now ready to make a more permanent one.
I like the bendable trim tabs that are used on the -12. If we change props it would be easier to adjust. Has anyone put one of these bendy tabs on a -6 rudder and, if so, what method did you use to attach it?
RV-6 panel is fine. Just... fine.
2019 VAF dues paid!
Old 05-24-2016, 12:28 PM
JonJay's Avatar
JonJay JonJay is offline
I used a wedge, but have seen plenty with a tab. Proseal is plenty strong enough but I have seen others pop rivet them on, obviously drilling through only one side of the rudder skin!
Flying out of Novato will make you a better pilot. Never seen a place with more cross wind.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-25-2016, 08:33 PM
lr172 lr172 is offline
I used balsa (RC model aileron stock). Once I had it adjusted to the correct size, I coated with epoxy and painted. I used RTV to hold it on the rudder. I find it less noticeable than at traditional trim tab.
Larry
Old 05-25-2016, 09:12 PM
Far North Texan Far North Texan is offline
We used a piece of scrap aluminum to make a tab. Stuck it on with double sided tape. Its been on for over 20 years so it must be good tape. If it ever blows off I plan to replace it with a wedge.
I would not recommend riveting one on, seems like that would just invite cracks.
RV-6A slow build,
serial # 21681. First flight March 1993
Dec 2019 donation paid
Old 05-26-2016, 08:38 AM
AllThumbs's Avatar
Thanks for all the input! I hadn't considered the possibility of cracks from riveting. Since many aircraft do rivet those tabs on there may be a doubler on the inside. I'll go back and look at some RV-12 plans to see how that tab was installed.
2019 VAF dues paid!
Old 06-02-2016, 01:19 AM
Pittsartist Pittsartist is offline
I made a trim tab from 1/4" clear lexan milled into a wedge shape about 1 1/2" wide. I adjusted by simply reducing it in overall length gradually (whilst secured with duct tape) and then when I was happy I glued it on with clear RTV.
I can't say it's invisible - but it's certainly hard to spot from more than 20' away. Also, there's no colour matching of paints or need for multiple colours if it interferes with your paint scheme. Finally, it could be removed without a trace.
[IMG]_MG_3009 by WIGY TV, on Flickr[/IMG]
Old 06-02-2016, 06:18 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Easy / Effective trim tab
Look up Gurney Flap . HFS recommended it to me. They are very small like .125 tall and VERY effective. Hold it on with tape and trim the length until the ball is centered, then rtv it on. Works like the straw taped to trailing edge as dicussed here before.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 06-02-2016, 08:15 AM
n816kc n816kc is offline
Default rudder trim
Tony Albano's trim solution is intriguing. Visually very low profile.
http://www.vansairforce.com/communit...ht=gurney+flap
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
