Old 05-25-2016, 06:50 PM
Pete G Pete G is offline
Default Occasional Rough Running Engine
I have an RV-6 with an IO-360 EXP, dual P Mags, using NGK auto plugs. My engine randomly runs rough at full power, just after liftoff on three occasions, I have observed the #3 cylinder EGT drop to below 700 degs while the other three cylinders are 1200-1300 degs. Reducing power resolved the roughness in each case and the #3 EGT went back to the 1200-1300 deg range. After today's event I landed and did a high (not full) power run-up at 2400 RPM. I checked each P MAG individually and found no problem. I did one trip around the pattern with no roughness. When this happened a few months ago I installed new plugs in my #3 cylinder on my A/P's advice. The problem returned today. This problem is persistent but random. Has anybody else encountered this circumstance? Any suggestions?
Old 05-25-2016, 07:22 PM
Stu McCurdy's Avatar
Stu McCurdy Stu McCurdy is offline
Default Rough engine with Electronic Ignition
I have an RV-8 equipped with IO-360-M1B with Slick Mag left and ElectroAir EI right side. I recently had a severe rough running engine after takeoff and landed. Long story short, it turned out to be the EI switch. One screw holding battery power wire ring terminal to bottom lug of switch had loosened causing ring terminal to float, causing intermittent contact, and caused the rough run. A good tightening allowed engine to again run smooth.
Stu McCurdy (Falcon)
RV-8, 78TX, Flying
Formation Flying, Inc (FFI)
Falcon Flight
Old 05-25-2016, 07:33 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
How many hours on the engine?
Any particular time of your flights that this happens----i e taxi, take off, cruise etc?
Have you heard the term "morning sickness" as it relates to these engines?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-25-2016, 08:21 PM
Weasel's Avatar
Weasel Weasel is offline
Originally Posted by Pete G View Post
I have an RV-6 with an IO-360 EXP, dual P Mags, using NGK auto plugs. My engine randomly runs rough at full power, just after liftoff on three occasions, I have observed the #3 cylinder EGT drop to below 700 degs while the other three cylinders are 1200-1300 degs. Reducing power resolved the roughness in each case and the #3 EGT went back to the 1200-1300 deg range. Has anybody else encountered this circumstance? Any suggestions?
I will be watching closely to see what you find.
I have almost the same thing happen to me randomly on the IO-540 in our -10.
In my case #1 cyl egt drops while engine runs rough a few seconds.
reducing RPM to ~2550 makes it smooth out and run fine again and then it will not repeat the problem sometimes for a long time.
I have checked the valve stems and guides for sticking valves per Lycoming SB no less than 3 times and have run a reamer through the guide with no joy.
Cyl and valves look great with bore scope.
Changed push-rod length to put valve lash closer to the middle of the published range.
Changed spark plugs.
Checked for water in the fuel (although it is always #1 cyl so it should not be a water problem)
Checked injector orfice for trash.
The way the cyl goes cold I dont think it is spark related because I have 2 independent igniton systems (lighspeed and Bendix)
Its killing me
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 05-25-2016, 08:40 PM
molson309 molson309 is offline
I once had a piece of trash in the fuel distribution spider that caused a rough running engine. It was a curl of black rubber in one of the ports, only visible when I pulled the piston out of the valve body.
Might be worth a look.
Mark Olson
RV-7A First flight 2005 Sold 2019
F1-EVO Rocket First flight 2010
Old 05-25-2016, 08:54 PM
brad walton brad walton is offline
I just recently reamed my #2 exhaust valve because of a similar sounding issue with occasional rough running, cold egt that would last for a very few seconds. Based on how tight the valve stem was in the guide, I am confident this was the problem.
Old 05-26-2016, 04:45 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
I would look at the injector and fuel spider. Small tiny things can do this and pass through.
David Brown
Old 05-26-2016, 05:10 AM
Mike H Mike H is offline
Could also be a hydraulic lifter unit collapsing.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 05-26-2016, 08:25 AM
To answer Mike's questions:
The motor has 600 hours since being overhauled by LyCon in 1999. I have put about 200 hours on it in the last two years. It has very good compressions, normal oil consumption, and runs strong 99.9% of the time.
The problem has occurred three times shortly following liftoff with a thoroughly warmed up engine, eg, second or third leg of a local area tour. It occurred once while leveling off from a descent at 9k'.
To all others, thanks for your thoughts and ideas.
Old 05-28-2016, 09:34 AM
lr172 lr172 is offline
+1
Excluding a stuck valve, your symptoms point to something floating around in that cylinders fuel delivery system. The immediate clearing on reduction of power points me there. I would pull off the spider and clean it, as well as flush out the line to affected cylinder.
Larry
