Old 05-22-2016, 09:56 AM
E. D. Eliot E. D. Eliot is offline
Default Additional wire runs under the floor?
I'm at the point of installing the bottom skin of the cockpit. Have heard that some here have had difficulty running the wires thru the installed snap bushings - so, my question is, should I install another set of snap bushings for possible future additional wire runs from the panel area to the tail of the airplane? Easy to do now but not so easy after the plane is flying. Your advise is appreciated.
Building finally
Old 05-22-2016, 12:56 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
I just finished to install the wiring harness. I had to slit some of the bushings because the BNC connectors (COM, ADS-B) won't go through.
Generally I did not have any difficulties to run the WH-00045 and WH-00046 incl. coax. wires and the pitot line through the bushings.
However, I have experience a tiny clearance issue between the cables and the flaperon mixer arm. Even though F-00049 wire plate protects the wires from rubing, the space there is marginal.
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 05-22-2016, 01:07 PM
RVTrumpet's Avatar
RVTrumpet RVTrumpet is offline
You should be fine with the amount of space given in the kit. It is a tight fit and you will have to slit some of the snap bushings. However, a little extra time taken while routing the harnesses to make sure that all the wires are running straight through the bushings (not accidentally coiled or twisted around one another) can go a long way in helping to best utilize the given space.
RV addict for life.
NOTE: The information, ideas, and opinions presented in this post are my own and not those of my employer. Build, test, and fly at your own risk.
Old 05-22-2016, 10:59 PM
gossend gossend is offline
Thumbs up Do it now!
I enlarged the holes for larger bushings and even createed extra ones. Boy was I glad I did! The space allowed by the designer is woefully too small, and almost impossible to enhance later. Do it now!
While you are at it, run extra wires for future "enhancements" or new gadgets you can't imagine at the moment. I ran six #22, two #20, one #18 and one RG400 coax from the panel shelf all the way to the baggage bulkhead and tied them off. The purists will frown and smirk at you, but just wait til they need to run another wire or two and you'll feel pretty smart
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with Aeromomentum AM15-HP engine
Old 05-22-2016, 11:03 PM
Default Re: Do it now!
Technically this makes your airplane EAB (not ELSA), but I didnt (and don't) care about that. It's your choice to make, though
Dick Gossen
gossend@gmail.com
Old 05-23-2016, 10:28 AM
Default Thank everyone
I appeciate the replies to my question - thank you all, Ed
Building finally
