05-21-2016, 06:18 AM
High EGT Warnings
One of my EGT signals gives me a warning every time I fly. Why should I care? All the other engine numbers are fine, and all the plugs are a nice Gray color. It runs great and I'm not inclined to worry about it. Should I?
I suspect a probe issue is causing it but even if the probe checks out fine, why would this be an issue?
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
05-21-2016, 06:32 AM
Super Moderator
AT what temp do you have the high alarm configured?
 Vic Syracuse
www.Baselegaviation.com
05-21-2016, 07:50 AM
I just had this issue with D-180 EMS. Replaced thermocouple and problem is fixed.
Dynon EGT, Hose Clamp, 0.75-1.25", Rotax
SKU: #100405-001 $47.00 shipped.
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 622
05-21-2016, 08:43 AM
Mike Bush wrote that "There is no limit for EGT."
The Savvy Aviator #59: EGT, CHT and Leaning
Joe Gores
RV-12 Flying
05-21-2016, 09:16 AM
If the EGT temperature is spiking is most likely a bad connection at the spade lugs or the DB pins.
05-21-2016, 12:55 PM
I had the right one go...ordered a couple of extra...replaced the right...working fine....guess what?
...the left one is acting funky.
I think there might be a bad batch out there imho.
Yeah..... you can fool with recrimping/new connectors - that might be it....
05-21-2016, 01:28 PM
Could you mention how many hours you got on your probes?
My right EGT probe acted funny after my annual with wild fluctuations ending with the red cross (no, not this one, the one on the Skyview  ). That was at 140 hour. It bothered me a while and I ordered a new unit but before installing it, I noticed that the wire going to the probe was very tight so I gave it some slack: problem solved. Twenty hours later it still works fine... and I have got a spare!
05-21-2016, 01:45 PM
As per post #3 above... I replaced my right EGT. It started acting up ~ 80 hours. It sort of healed itself for the next 15 hours and just two weeks ago it decided to give me grief. I tried re-crimping the connectors and fooled myself into thinking I had it fixed. New thermocouple purchased directly from Dynon fixed the problem and easy install with removing top cowl only.
Jim Stricker
EAA #499867
05-21-2016, 07:12 PM
Super Moderator
I agree. That's why I asked where you had your limits set at. I see a number of airplanes that have EGT limits set around 1400 degrees.
Vic
 Vic Syracuse
05-21-2016, 08:05 PM
You can always swap it with another probe (like 1&3 or 2&4) and see if the reading follows the probe or cylinder. Don't need to swap the connections. The probes do fail, mostly open up or wiring failure. If you've installed all the probes the same distance down the pipes from the flanges the EGT's should all be pretty close if the mixtures are closely equal in all the cylinders.
