  #21
Old 05-17-2016, 05:23 PM
Terrybrd Terrybrd is offline
Default paint stick taped onto filler hose
I measured how far it is from the filler opening to the top of the gas tank.
Then I got the filler hose on the pump and hold a paint stick at a 90 degree angle at that distance and tape it with a X pattern to hold the stick onto the hose.
I then insert the hose all the way till it stops with the stick on the top of the opening.
Then all I have to do is pump the fuel until the automatic stop on the tip of the hose pump shuts off .
This gives me the same amount of fuel every time.
Looks kind of cheap but does the job.
Terry
