  #11
Old 05-12-2016, 02:34 PM
rapid_ascent rapid_ascent is offline
Well there are some fuselage bulkhead pieces and the lonerons that are shipped with the wing kit so at least on the RV-7 I'm not sure how you could build the fuselage first.
Independent of that I would say that the wings are more repetitive and it does take some time. I would stick with the wings first.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 05-12-2016, 04:24 PM
salto salto is offline
CWOOD if you go with the fuselage next then order W-00026 as well. You will need this alignment template in two places, the flap actuating rod and the canopy release mechanism. It comes in the wing kit so you will be held up without it. Couldn't be more than a couple of bucks.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 05-12-2016, 05:12 PM
Ron B. Ron B. is offline
Not so on the RV-14.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 05-13-2016, 12:04 PM
czechsix's Avatar
czechsix czechsix is offline
I'm up to my elbows in proseal right now working on the tanks. As this is my second slow-build RV, I agree with others who have stated that the wings are the most time consuming and most tedious part of the airframe build. Once you've seen one rib, you've seen 'em all. If I could comfortably part with the cash for QB wings I'd do it in a heartbeat, but if you can't, I'd recommend just getting them done and out of the way as soon as possible. Then you can go on to the fuselage which is a lot more fun.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
