Old 02-26-2007, 12:32 PM
ops_geek ops_geek is offline
Question Empennage width?
Hi all-
What's the span on the empennage? How big does my garage door have to be to get the thing out when I'm done?
I have one of those two-door garages with fairly skinny doors. The mirrors on my wife's mini van barely clear going in...
Hate to have a 9'6" tail behind a 8'6" door!
Geek out...
RV-8: Empennage underway
N406RR reserved
Old 02-26-2007, 12:42 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Not answering your question directly because I'm building a 9 (with a 10-ft HS) but the empennage is easily removed later on. A lot (perhaps most?) builders take it off once it's initially fitted because it just makes it harder working around the plane. Then just re-install it on final assembly at the airport. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-26-2007, 01:00 PM
AX-O's Avatar
AX-O AX-O is offline
I am not home so I can't measure but I will say that most people remove the tail assembly prior to transporting the aircraft to the airport. You don't want to drive down the street and have a car or a pole smack the HS/elevator. Mine is hanging on the wall right now. Before it was hanging, the tail assembly fit in my home office trough a normal door. I will measure it when I get home if no one gets to it first.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 02-26-2007, 01:06 PM
G-force's Avatar
G-force G-force is offline
100" without fiberglass tips.
Mike Sumner
Castaic, Ca
