Old 04-25-2016, 07:05 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by jswareiv View Post
Cylinder #2 runs hot and until I get the wheel pants on, I'll have to limit more flying. Hopefully more speed, less drag will help that. I have been having to fly it rich to help keep it below 400, so I'll be replacing some spark plugs, but better than replacing cylinders.
Speed will help, but it's not the root of the problem. A 390 can be cooled at low speed and high power. Look hard at sealing. If you don't get it straightened out in Phase 1, fly it up here.
This was all knobs forward from 200 to 15,000, a data gathering run at 125 knots true all the way. Full rich, cowl door open, so a fair equivalent to where you are now.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-25-2016, 07:59 AM
jswareiv jswareiv is offline
Default CHT temps.
Thanks Dan, I'll keep monitoring it.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW - Sold
Old 04-25-2016, 08:23 AM
Shanna Linton Shanna Linton is offline
Thumbs up Congrats!
Congratulations on the first flight! Just watched the video on your website. I love to see RV Grins!
Old 04-25-2016, 09:45 AM
Tilford's Avatar
Tilford Tilford is offline
Default Thanks! Great timing.
Stoney,
Congratulations! and thanks for the motivation. It comes at a great time for me as I just finished inventorying my fuselage kit and have that overwhelming feeling of, what am I supposed to do with all of these non-deburred parts.
Thanks again for the motivation, I look forward to more photos, videos, and performance info.
Sincerely,
Greg
RV-14A Fuselage Complete.
Old 04-25-2016, 11:40 AM
BobTurner BobTurner is online now
Do you have the same air dams in front of #1&2 cylinders as the -10? Many of us have cut them down to lower the front cht's.
Old 04-25-2016, 02:29 PM
TimO TimO is offline
Bob,
Thankfully on the RV-14 they are removable, so it wouldn't be too hard to experiment. It may be worth taking them off and creating new ones that are slightly shorter for #2 and seeing how it goes.
Tim
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1400+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 350+ hours http://www.MyRV14.com
Old 04-25-2016, 02:41 PM
I'm not sure if they are the same as the 10, I was thinking about removing it, but first I am going to see if the wheel pants help.
Stoney
Old 04-26-2016, 06:54 AM
eriddler's Avatar
eriddler eriddler is offline
Question Slow?
Just curious about the 'slow' comment...more in reference to acro or general performance?
Sean 'Fog' Leaman
USAF // F-15E Eval WSO
Future RV builder (maybe -8, er -14, er -10....)
Old 04-26-2016, 07:40 AM
Default Acro & Speed
Acro was normal, full loop with no issues and a couple of rolls, easy breazy. I shouldn't say it is slow yet, because I've had to stay at lower altitudes <4,000'. I haven't gotten over 145KTS yet. Once I get the wheel pants on, I will post again with any change in the numbers. I am hoping that will solve my cylinder temp issue, then I'm going to take it up to 8,000' and see what it will do. I'm expecting at least 180KTS. Definitely within the next couple of weeks.
Stoney
