Old 04-23-2016, 09:03 AM
olderthandirt olderthandirt is offline
Default New engine lifting
I just picked up the Rotax engine and wondering how others have lifted it from box...also lifting while working on it and installing it to firewall..thanks
Retired Firefighter/Para-Medic
Sold 182 Skyelane
sold Super Cub
Building RV 12 E-LSA
Paid thru 2016, even though exempt
RV 12 completed, waiting DAR
Old 04-23-2016, 09:53 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Get the sides of the box removed and get it all unbolted from the mount. It pretty easy for 2 people to lift it.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 04-23-2016, 11:29 AM
The instructions say remove an exhaust bolt and use that as a lift point, but I wrapped a Kevlar sling around the cylinders and lifted it with a shop crane I got at HF. I left the mounting angles attached so it could sit on my work table while I made all the changes and shroud specified in the KAI.
Old 04-23-2016, 03:02 PM
yankee-flyer yankee-flyer is offline
Default Two of us
Picked it up an set on on the bench. An engine hoist (someone in a nearby EAA chapter has one) is just about requited to bolt it to the airplane-- lots of tweaking required to get eveything aligned.
Old 04-23-2016, 08:54 PM
Ueli N Ueli N is offline
I had the fuselage on 3 inexpensive 4 wheel dollies from Harbor Fright, the wheels fit perfectly into them.
When I was ready to mount the engine I put it on 2 saw horses, leveled and shimmed for height, then moved the fuselage in position and mounted it.
It was an easy one man job.
120HB
Old 04-26-2016, 09:10 PM
waterboy2110 waterboy2110 is offline
There are two bolt holes in the case behind the reduction unit. Those holes take the same bolts as the carbs (not where the pitot mounts). I took a carb bolt down to the HW store and picked up a couple bolts, nuts, washers and a foot of chain. Screwed the bolts in, backed them up with the nuts and had the chain at the bolt heads with washers. Since the lifting hook for my O-235 is one AN3 case bolt this had to be over kill. Once I had the ring on I followed Vans directions for lifting since this area is covered by the cooling shroud.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P/IA Rotax iRMT 9 Series Maintenance
EAA Technical Counselor
RV12 Flying.
Old 04-27-2016, 06:36 AM
Default lifting engine
I made a bracket that fit on engine where two holes are behind gear case..lifted engine out of box and placed on bench, then removed bracket and fitted fiberglass air box to top of engine, now engine is hung from engine hoist by two straps, one on engine mount in rear and one around gear case..all balance nicely and made installing engine easy...
Sold 182 Skyelane
sold Super Cub
Old 04-27-2016, 09:45 AM
rvbuilder2002's Avatar
I just sling the engine with a strap or rope looped through the two intake manifolds.
I balances relatively well at that point.
All stripped down the engine only weighs about 130 lbs so it is not much load on the manifolds.
Scott McDaniels
Hubbard, Oregon
Old 08-13-2016, 11:16 PM
Gandalf Gandalf is offline
It was a fairly easy two man lift onto a 1000 pound pneumatic rolling table.
