04-16-2016, 05:26 PM
Ready to trim fiberglass top - what tools work?
Hello,
I'm ready to trim the top to place it in fuselage. Will you please suggest tools, disks, blades, sanders that work and last?
Thank you!
Yuri
DA40
RV-10 - build in progress
04-16-2016, 06:08 PM
I had pretty good luck with the diamond cutoff wheels for the dremel tool https://www.dremel.com/en-us/Accesso...aspx?pid=EZ545. I think I used two of them on about half the fiberglass on the plane.
Before finding the diamond cutoff wheel I used the Harbor Freight metal body saw (which was OK but not great) http://www.harborfreight.com/air-too...saw-91753.html. I also used the regular fiber cutoff wheels for the dremel. Again worked OK but not great. My compressor would not keep up with the typical cutoff air tools.
I did a lot of cutting short of your mark and sanding up to it with belt sander or drum too.
Ben Westfall
RV-10 (phase 1 flight testing)
Coeur d'Alene, ID
04-16-2016, 08:07 PM
4 inch angle grinder.
Actual repeat offender.
04-16-2016, 08:26 PM
I used the multi-tool from Harbor Freight. You go through blades a little faster than the name brands, like Fein, but it's significantly less expensive.
04-16-2016, 09:50 PM
Permagrit tools!
They make a saber saw permagrit blade. It works great...Very easy to be accurate and it makes almost no dust, more like sawdust...coarser. WAAAYYY better than the high speed cutoff wheels. I also did not have much luck with the body saw. The diamond wheel for the dremel works good but there is a lot of cutting. I tried almost every way and the Permagrit blade worked the best for me.
I would also recommend the Permagrit sanding tools and burrs. They make working with fiberglass as easy as working with balsa wood...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
04-17-2016, 06:50 AM
One more vote for the Multi Tool from HF. Just make sure you get the carbide blade, as the fiberglass eats the HSS blades.
It walked through the canopy easily with little dust
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
04-17-2016, 07:07 AM
04-17-2016, 08:20 AM
I bought the cheapest "wig-wag" tool HF makes and it works great for the operations we do in plumbing, like cutting open plaster walls or the occasional frozen nut. It's the accessories that run the cost up and HF charges enough that it pays to buy better and use the right accessory for the job.
I consider HF tools to be "throw away" tools, that we can equally use for what they are intended, or as a hammer if you need it in a pinch.
The price is right so don't overthink it. ;-)
-Marc
RV-10
N814RV
2020 Donation Made
04-17-2016, 09:19 AM
I'm a big fan of the oscillating tool for cutting. Get the right blades. The BIG advantage is it doesn't throw a bunch of dust. It makes very little mess relative to a spinning disc. (Ask me how I know)... Works great for sanding in tight spaces too.
http://t.harborfreight.com/power-too...ool-62279.html
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system!
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
04-18-2016, 08:06 AM
Thank you all so much! I will go shopping.
Yuri
DA40
