Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #41
Old 01-14-2016, 09:49 PM
chrishalfman's Avatar
chrishalfman chrishalfman is offline
Originally Posted by RVbySDI View Post
..... There is a gentleman in Kansas who retains the rights to manufacture the Ellipse props designed by Paul Lipps. I cannot recall his name but he does fly an RV6 with an Ellipse prop. He has also designed his wingtips in the similar shape as the prop tips. It is a unique looking RV6 when you see it......
I believe that gentleman is Jim Smith.
http://www.vansairforce.com/communit...p?t-54702.html
Chris Halfman
La Vista, NE
-7A, 300+ hours on the Hobbs, ECi O-360 185 hp, GA200L Whirlwind prop
Anything I post on here may not be the best way, the right way, the only way, or even an accepted way to do something, but it's how I did it. Use the information accordingly.
Old 01-15-2016, 11:32 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Thank you for posting. He gave me a business card several years ago but I have not been able to locate it or recall his name.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 04-14-2016, 06:43 PM
maus92 maus92 is offline
Hello:
I just did a WOT test on my RV-8A to help the Catto peeps with my (potential) prop order. I should note that my nose gear fairing is currently removed. Anyway, the stats:
166Kts TAS @8,500' 2650 RPM, 2 bladed Sensenich FP metal prop.
This seems a tad slow.... What should I expect from a 3-bladed Catto? I'm leaning towards a prop slightly pitched for speed over climb - my home field has 2 long paved runways, and most airports I visit are at least 2000.' However, I'm thinking about joining in on formation flying, and those guys usually have CS (I'm not going to make that jump just yet.)
Thx.
UPDATED INFO: Also, developing 73% power, full rich, 29F OAT.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 04-14-2016, 06:53 PM
N941WR's Avatar
N941WR N941WR is offline
Not an -8 but my O-360 powered -9 with a 2 bladed Catto will true out at 174 kts at 8,000' DA. All in and leaned for best power.
While I have a longer wing and no nose wheel, the speeds should be closer than that.
The 2,000' runway should not be an issue.
When doing formation work, just make sure lead knows and if they are any good, they will not close the throttle on you so they can watch you go sailing on by.
No worries, enjoy the Catto.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-15-2016, 10:42 AM
rvbuilder2002's Avatar
Take-off distance for an RV-8A with a 180 HP and a constant speed prop is spec'ed at 575' so figure on a fixed Catto doing about 650-700 at gross weight (still very good all things considered)
Scott McDaniels
Hubbard, Oregon
Old 04-15-2016, 10:44 AM
brad walton brad walton is offline
Don't underestimate the value of the nose wheel fairing. It's got to be worth several knots at least.
I asked Catto for Van's numbers on my RV8 with a Superior IO360. I get 178 ktas at 2700 rpm's from my 3 blade 68x75 at 8000 feet da.
Old 04-15-2016, 02:29 PM
The fairing is off because I installed the redesigned fork / shortened nose gear leg late last summer, and haven't modified the fairing to accept the new bracket arrangement. It's on the list though...
CA
Old 03-23-2020, 11:33 PM
MikeS MikeS is offline
Default Paul's old entries?
It was some time ago but the last time I checked into this forum I found Paul's old entries . . . but now either I'm typing a name wrong or Paul's entries have been moved into some less accessible area?
Anybody can direct me please?
Mike
