Old 04-13-2016, 06:56 PM
Sam Staton Sam Staton is offline
Default CO Detector
Need to try to get a consensus here - what are you guys using for CO detectors? Thanks in advance!
RV6 N585SS - building on!
O-360-A1G6D converted to A1A
Dual Powertek EFII
VPX-Pro
Astronics PPS
Hartzell C/S
Dynon SV1000 & SV700
Old 04-13-2016, 07:10 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
After reading this article I got the CO Expert's detector.
The only problem is that it goes off every time it gets a sniff of exhaust, like when taxying with the canopy cracked open. But it was quick to react when I had an exhaust flange fail. I opened the fresh air vent and landed at the nearest airport. I'm still happy with my choice even if I have to explain the beeping to my passengers.
Old 04-13-2016, 07:24 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I use a Flight Data Systems http://www.aircraftspruce.com/catalo...0carbondet.php
One thing to check out is the life, and cost to replace the detector module. FDS units have long life and reasonable cost to replace detectors.
Small, light weight, and uses a built in fan to pull sample air through the unit, so should be able to detect CO a bit quicker than non fan units-------at least that is how I see it.
Audio warning, and EFIS script as well as red light on panel.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-14-2016, 06:12 AM
swordtail swordtail is offline
I use one.
Old 04-14-2016, 06:43 AM
togaflyer togaflyer is offline
I looked at the Gardian, but along with the purchase price of around 300-350 dollars., every five years it requires service at 200 dollars. It is a nice unit. But it does cost.
Old 04-14-2016, 06:48 AM
SmilingJack's Avatar
I purchased the Guardian 252F and yes, normally you have to service it every 5 years, but they told me since they no longer make the 252F I have to buy a new one
Yes, they give a little core credit, but my unit it built into the panel and now I would have to rebuilt the hole to fit a smaller unit they sell.
John Mastro
RV-8
Old 04-14-2016, 07:07 AM
219PB 219PB is offline
What about this one? It is about 2.5" x 4". Cost is $199 and lasts for 5 years. It reads low levels of CO, has a digital display and a silence button in the event it is going off while the canopy is open during taxi.
It can be found at Aeromedix.com
http://www.aeromedix.com/ultra-low-l...-experts-2016/
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 04-14-2016, 07:40 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
I got the same one, with audio alerts and EFIS annunciation. It also gives a "cabin altitude" audio alert at 10k feet to remind you about O2.
I've been very happy with it so far!
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 04-14-2016, 08:25 AM
b1driver b1driver is offline
Wonder if anyone has done this regarding this issue:
http://www.dfrobot.com/index.php?rou...log/blog&id=70
Luis G.
RV-6A O-320 D3G
Old 04-14-2016, 09:27 AM
BJUST BJUST is offline
I use the Pocket CO manufactured by KWJ engineering
http://www.pilotmall.com/product/Poc...FUZrfgod7goEQA
Also available from Amazon
Bayne
RV-7A
