I will try to expound on it a little more.
The magenta text is added from the original post.
From
http://www.gen-aircraft-hardware.com...Plane_proj.asp
You will see on the site pictures that go with the paragraph below.
It is for the RV6
The bend on the elevator tab was a bit fun. I clamped a piece of 1/8th inch aluminum inside the tab
and also held the 1/8th in bar in a vise at the same time, before assembly, and then I used a peewee roller as shown below. Radius the aluminum before clamping it
so as not to crack the area where you are bending it., then once clamped carefully, roll
the roller over it slowly back and forth until it is the angle you want, focusing the pressure as close as possible to the part you want to bend. I fit it all up and drilled the holes for the blind rivets
after bending the tabs but before I assembled it. The rivets you see are CR3214-4-2 rivets. These have almost an identical head size of the MS20426AD3 rivets, but the have 1/8"shank and are considered a structural blind rivet.
I suggest dimpling for a 3/32 and then drilling it to an1/8th hole before putting in the rivets. I used two spaced evenly on each end. I know the grip is a little long but they all worked great for me and the strength should be more than adequate.
BTW the roller is a wallpaper tool. it was originally used by me for installing de-ice boots when I was working on planes for a living.
We sell these rivet in packs of 10 p/n CR3214-4-2pkg/10
You wont need the hundred pack without the /10 as a suffix unless you fall in love with these little blind "oops" rivets, then you will want more.
