  #11
Old 04-13-2016, 06:52 PM
BABALU BABALU is offline
I have a zinc eye bolt anchored in the concrete floor , I use it to attach a tie down strap to pull the tail down and check my nose wheel . Is it fesible to ground the plane to that bolt if need be?
A C Tyler
RV 9A
Old 04-13-2016, 07:27 PM
Infidel's Avatar
Infidel Infidel is offline
Originally Posted by simpkinsona View Post
Would you mind posting a calendar with where you'll be for the rest of the year?
You owe me an IPad cleaning! Lol!!!!
Old 04-13-2016, 07:48 PM
Kyle Boatright Kyle Boatright is online now
A ground point should be a copper rod driven several feet into the soil. I would imagine an eye bolt drilled into the concrete floor would be a very poor conductor. If you don't want to drill a hole and drive a 4' copper rod, a better solution would probably be to ground to a piece of steel hangar structure, since the hangar itself is <probably> well grounded.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-13-2016, 08:04 PM
aerhed aerhed is offline
Imagine a day when your entire airframe is a solid state structural battery that can't ignite and just has a plug in motor with no wire connections to fail. The stories are gonna get so boring.
Actual repeat offender.
Old 04-13-2016, 08:31 PM
diamond diamond is offline
You might as well send me some new underbritches while your at it. size 34.
Old 04-13-2016, 08:50 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Gasoline flowing thru a nonconductive plastic or rubber fuel line/funnel/whatever makes a pretty darn good Van de Graaff generator. Ever wonder why teflon fuel hose has a conductive carbon liner inside?
Neal Howard
Airplaneless once again...
Old 04-14-2016, 04:52 AM
Good point. I therefore Delete stupid question.
A C Tyler
RV 9A
Old 04-14-2016, 05:07 AM
Default Electrical fires
Fuel fires are dangerous but they are not the only type of fires that occur in airplanes.
Electrical fires can occur for many reasons including chafed insulation causing a short; improper gauge wire; old / stuck breaker; dirt in a reostat; critters chewing on wires; failed voltage regulator; yada yada
Toxic fumes and smoke can put an end to your day even if the heat of the fire doesn't.
Old 04-14-2016, 06:34 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by BillL View Post
Great link Bill.
Originally Posted by Champ View Post
Is it OK to use a plastic fuel container if you run a lead into it?
Sure hope so!
Seriously, the plastic container is in contact with the metal funnel, the fuel in the container, and the submerged wire, and all are electrically common.
If you used a metal container could you just clip the funnel lead to it without the wire into the bottom?
Yes, but as noted in the page Bill linked, a metal can may have a liner or other interior coating. I would always use the submerged wire.
What gauge wire works?
Mine is ordinary stranded lamp cord.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-14-2016, 08:46 AM
wirejock's Avatar
wirejock wirejock is offline
Default Personal ground
(snip)...
Don't forget to discharge yourself before reaching into the fuel vapor zone.
How about a personal wrist strap ground?
In our data centers, we had to wear wrist ground straps. They have a coiled wire with an aligator clip. Seems like a good way to keep your body at the same ground potential.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
