04-11-2016, 06:59 PM
Real world performance?
I will be flying an RV-6A from TX to SC on Thursday. It is 180HP with a Hartzell blended airfoil prop. I know there are variables, but for those who are flying with this specific configuration, what cruise TAS and fuel burns are you seeing at, say, 11,000'?
Thanks in advance.
Jesse Saint
04-11-2016, 07:23 PM
I forgot to mention, it's carbureted.
Jesse Saint
04-12-2016, 06:45 AM
Mines a taildragger IO360. I burn about 8.3 gph cruising 157 kts TAS running 50 deg LOP @ 8k. Not sure if its typical for a RV7 or my inexperience at LOP but I get better speed on less fuel burn at lower altitudes.
04-12-2016, 06:52 AM
Thanks in advance.
O-360 fixed pitched prop. 165kts true at 9.1 gph 10,500 to 12,500.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
04-12-2016, 09:40 AM
My RV6 with O-360, CS prop will cruise at 155-160 kts @ 10,000 ft burning 8 gph lean of peak. Sometimes more, sometimes less depending on load. This is at about 65% power.
Ken Harrill
RV-6
04-12-2016, 11:20 AM
Wow - the variability here is pretty interesting. I'm wondering what some of the variables might be. - Is electronic ignition, which may reduce fuel flows by 1-1.5GPH or possibly more present?
- Are fuel flows being measured instantaneously (i.e. fuel flow meter) or via block (fuel burned for the flight divided by flight time)?
- Has the airspeed indicated been calibrated, and if so what is the margin of error?
In my case, RV-6A w/IO-360-B1B, dual P-Mags, Hartzell 74" BA prop, I see 6.2GPH at 155KTAS at 11k density altitude. Pushing it up to 165KTAS will cost me 7.9GPH. 175KTAS will cost me 8.9GPH. Vmax at 11k DA was 179KTAS, which cost 9.6GPH. Fuel flows are measured via a Dynon EMS using the "Red Cube" located between the throttle body and fuel divider and are LOP except for Vmax, which was leaned for best power. True airspeed values are taking the 2.8% error at these altitudes shown by the airspeed indicators into account as well.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
04-14-2016, 08:00 PM
Well, it turns out I got about 155ktas on about 7.5-8gph at 11k and about 165ktas on ??? At 9k. No fuel flow and only a single EGT needle, so not very easy to dial in. The ??? Is because I didn't fill up after landing, so I don't know what it burned. Thanks, all, for the help. I was hoping to make it nonstop, and maybe could have by pulling back a little, but with a faulty left tank gauge and no flow meter, I wasn't going to push it.
Jesse Saint
04-14-2016, 08:11 PM
When I was commuting between Houston, TX and Greenville, SC with my -9 I would stop half way and top off. Except that one time when I was up at 15.5 being pushed by a 50+ knot tailwind and made it nonstop and only burned 24 gallons.
You did good.
Where in SC did you drop it off?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
04-14-2016, 08:19 PM
Just seeing this thread so already OBE but still thought I would throw my numbers out.
RV-6A/IO-360-B2B/FP 85" pitch
@ 11Kft
75% power I see 175 KTAS burning 9.8 leaning to peak EGT
65% power I see 164 KTAS burning 8.9 leaning to peak EGT
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
04-14-2016, 08:26 PM
Originally Posted by N941WR
You did good.
S17 near Augusta.
Jesse Saint
