Old 04-08-2016, 10:19 AM
moll780 moll780 is offline
Default Islip KSIP from Boston recommendation
So it looks like part of a summer trip we'll be taking will be from Norwood (West of Boston) to KISP. (after OSH we'll be exploring the east for a couple of weeks)
I have some questions for those that fly in this area:
1. cross the sound or go around?
2. recommendations for flying around the sound and up long Island?
3. dont bother; land in CT and take the train?
thanks in advance!
--2008 RV-9A
Austin TX
Old 04-08-2016, 10:42 AM
AdamB AdamB is offline
I'd say cross the sound. I fly out of Lawrence (KLWM; near Norwood) and the IFR route down the coast is usually V16 leaving Norwich (ORW). Then continue down V16 along Long Island once you get to CCC. I fly this route often and the stretch over the water isn't too long.
I'd suggest you check out Block Island. It's actually in RI, but off the tip of Long Island.
Neat little Island with a restaurant on field. Town is a short cab ride away.
RV10 - #41687
http://adamsrv10.wordpress.com
N56AB Reserved
Old 04-08-2016, 11:09 AM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
Yes, cross the sound. Check out Block Island if you have the time. Fishers Island is also a nice landing. Not much on that field though but worth the sights. Fly the Hudson River.
Old 04-08-2016, 11:21 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Did Block Island a few years ago - highly recommended. Make sure you have enough gas for your next leg as they do not have fuel.
Old 04-08-2016, 12:09 PM
ok.
So fly over the sound.
Block Island and I was thinking of stopping at MVY.
Hudson river.
We're planning on heading to Warshington (as pronounced around here) for a few days then Hotlanta. Perhaps.
Nothing in stone.
Any other recommendations?
Thanks!!
--2008 RV-9A
Austin TX
Old 04-08-2016, 01:11 PM
kinger's Avatar
kinger kinger is offline
http://www.oldrhinebeck.org
http://owlshead.org/
SWF -- http://www.orangecountychoppers.com/
James King
RV-7
919
Old 04-08-2016, 01:33 PM
aparchment's Avatar
aparchment aparchment is offline
Default More recommendations
Yes, definitely cross the sound. Do it at its narrowest point if you are concerned. It's really not that wide, and if you keep enough altitude you have a lot of gliding options. The air traffic doesn't get crazy until you get closer to NYC and JFK / LGA. That said, it is well worth a trip down the Hudson River VFR corridor to see the Manhattan skyline from under 1000 feet. If you do this please brief it well. There are clearly defined exit and entry points, and numerous reporting waypoints that everyone uses. Sightseeting helis frequent this corridor, usually at lower altitudes, so use caution.
While in the Boston area you should definitely fly the coast up to Kennebunkport or Portland Maine. If you go that far up I will give you a bunch of tips. If you choose to stay south of Boston, then check these out:
Martha's Vineyard is beautiful and worth exploring at low altitude. There is a very scenic set of grass runways on the southern side of the island called Katama. I found them to be bumpy, by your mileage may vary. There is a restaurant on the field and the field is within walking distance of a spectacular beach.
Chatham on the Cape is another nice stop. You could take a taxi into town and have lunch at a bunch of nice spots, including the pricey but very pretty Chatham Bar Inn. While there, maybe you should fit in a great white shark cruise. The white sharks are back in the Cape in significant numbers, and sightings are on the upswing.
Provincetown on the tip of the cape is worth a stop. The beach is right across from the airport and the dunes are very pretty. If you keep your eyes peeled you may also see whales off the northern coast. I have been fortunate enough to see them feeding a couple of times. A trip into PTown, as the locals call it, is worth it for the restaurants, but don't go if you are easily offended by alternate lifestyles. This isn't a judgement either way, just a statement that there are many overtly sexual themes on signs, shops, restaurants - much like Key West.
The tip of Long Island has Montauk airport. It's a great little spot. I have avoided it during the peak season because I bet it is full of interesting personalities, but in the off season I like to visit a great little seafood restaurant down the road called The Inlet. It offers very fresh and well prepared seafood, as you would expect considering they are down the street from where the commercial fishing boats unload their catch.
I didn't do a ton of flying when I lived outside DC, but if you get a chance the Smithsonian museums are amazing and free. Udvar Hazy at Dulles Airport and the Air & Space in town are musts for any pilot.
Have fun and I hope that helps.
Originally Posted by moll780 View Post
ok.
Hudson river.
Nothing in stone.
Thanks!!
Antony
RV-7A
Empenage complete, wings complete, tip-up canopy complete, starting wiring ...
Old 04-08-2016, 01:35 PM
aparchment's Avatar
Default Ditto on SWF
I used to stop at SWF all the time as a fuel stop on the way to PA from ME. It's a very nice airport and close to Orange County Choppers if you like bikes. There was an older guy who worked the FBO who would loan people a car if they wanted to visit OCC.
Antony
RV-7A
Old 04-08-2016, 01:40 PM
AndyRV7's Avatar
If you are going to ATL, then you can travel the coast virtually the whole way. I would add Tangier Island in the Chesapeake Bay, and you will fly right over First Flight airport, a must do pilgrimage for all pilots and their planes.
Old 04-08-2016, 05:26 PM
Flying EMT's Avatar
Flying EMT Flying EMT is offline
Default ISP
Not unless you have previous arrangements, Islip is an expensive place to land and keep your plane. If you can, HWV Brookhaven would be alot cheaper. I'm at FOK and if that would work, I might be able to find a hangar for you. As far as the sound, just start at Westerly, RI and island hop to the North Fork. Some interesting Fort ruins on those islands. Ben
Ben Hubbard
180 hp RV-4
Enstrom F-28C
1979 Decathlon (In recovering mode)
KFOK Long Island, N.Y.
Last edited by Flying EMT : 04-09-2016 at 10:30 AM. Reason: Put wrong airport code in
