Old 03-29-2016, 11:46 AM
Lindyshambaugh Lindyshambaugh is offline
Default Rear Window Seal
Has any one come up with a good...and neat...way of sealing the rear window? There has got to be a better way than prose all. Thanks!
Old 03-29-2016, 11:54 AM
KeithB's Avatar
KeithB KeithB is offline
I will be using Sikaflex, continuing from my canopy work. This eliminates the screws, too.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
Old 03-29-2016, 12:39 PM
rvbuilder2002's Avatar
What ever you use has to be paintable.
A clean way to do it is to mask and paint the portion of the window that is inside behind the skin. Then it doesn't matter what the sealant looks like because it is not visible from inside.
Scott McDaniels
Hubbard, Oregon
Old 03-29-2016, 01:55 PM
Ron B. Ron B. is offline
At least as of today I can tell you that the rear window can be removed after the Proseal has cured. I used Loctite on the screws as per rev. 0 after reading rev. 1 and forgetting that Loctite was a mistake and updated. Dang memory or rather lack thereof .
I had done a half decent job with the Proseal , but I get another shot at improving. I will mask off a larger area both on the acrylic and alum. so I can try and force a larger amount in-between the alum. and acrylic and hopefully have a completely filled seal. I had a few air spots on my first try.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
