Old 03-28-2016, 09:00 PM
Walt's Avatar
Walt Walt is offline
I'm not a bearing expert but according to Timken 0 preload is ideal for taper bearings.
http://www.timken.com/EN-US/Knowledg...r-Bearings.pdf
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-28-2016, 09:42 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default I have shims
Originally Posted by woxofswa View Post
One of my main wheel retaining nuts fits perfectly with its retaining pin holes. However, the other side is ever so slightly off on the shy side leaving just a tiny bit of wiggle. Advancing to the next hole is too tight and blocks enough of the axle hole to not allow the pin through.
Some say that a tiny bit of slop is okay but I would like to have it dialed in.
I know I can drill new holes 90 degrees off the current holes, but that counting turns process is still kind of imprecise.
What I'd like to try is putting a shim between the nut and the bearing face. Something like a modified retaining ring or thin washer(s).
I was wondering if anyone else may have had the same idea and discovered a source for the right size of shim?
I have some axle shims at my hangar. I think they are .005 and .010 thick. If you are interested I can mail you some.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 03-28-2016, 10:59 PM
woxofswa woxofswa is offline
Thanks for the offer. I ordered a package of 10 from Grainger.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
Old 03-29-2016, 06:53 AM
F1R F1R is offline
http://static.veracart.com/matco/ite.../document1.pdf
Page 11
"Timken specifications state, for example, that the two 1.25
inch tapered roller bearings used on a Matco WE51 will
produce between 18-26 inch pounds of torque (drag) when
properly installed."
