Old 03-28-2016, 12:47 PM
NavyS3BNFO NavyS3BNFO is offline
Originally Posted by Robin8er View Post
Nobody can really argue about using a name brand aircraft primer on an aircraft.
Sounds like a challenge. Sorry, I couldn't resist...
RV-8 empennage DONE
Wings 99% done
Fuselage in progress
Old 03-28-2016, 01:07 PM
spark68 spark68 is offline
Originally Posted by Boomer506 View Post
I'm on my second project and have become a big fan of sponge brushing Variprime 615S.
That's a good tip Boomer. I didn't know Variprime was still available. I like the brush idea.
I believe that the prep is as important as what kind of primer you use. All primers will provide some level of protection if they adhere properly. Aluminum oxidizes quickly after cleaning so we need to get the primer on soon after cleaning.
I am using an acid wash scrub with scotchbrite pad and IO water rinse, and two part expoxy (automotive), or spray can primer for small parts that don't warrant a spray gun with all the clean up involved.
There is a whole section of the forum devoted to primer, check it out when you have an evening free.
Mark Curley
RV-6 (under construction)
dues paid 2020
