Old 03-18-2016, 10:13 PM
skyking902001's Avatar
skyking902001 skyking902001 is offline
Default Oil Cooler Mounting
Need some advice from the wizards! I have cut the rear baffle for the oil cooler and drilled the 705A for nutplates, etc. The lower inboard nutplate is in contact with a cooling fin. If I insert a bolt and get 1 thread showing, it contacts the cooling fin enough to slightly push the baffle to the rear. My question--is it ok to grind a small relief in the cooling fin? If not, looks like I will need to re-order parts and start again in this area. If I raise the oil cooler enough to clear the fin, I am getting real close to contacting the cowl. Thanks in advance. Baffles--blah!
[IMG][/IMG]
Steve Riffe
RV-8
N23SR
Dues paid to 12-1-20
www.mykitlog.com/skyking90200
Old 03-18-2016, 10:17 PM
Blain's Avatar
Blain Blain is offline
Default Me too
Awaiting an answer to your concern. I'm building that very part tonight.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2020(my reminder)
Old 03-19-2016, 05:04 AM
Captain_John's Avatar
I don't recall having this problem. Perhaps my cooler was mounted higher?
You say that the oil cooler would be real close to the cowling if you raised it. Well, that is where you want it for best cooling.
I say raise it.
My two...
CJ
The experiment works!
Old 03-19-2016, 05:31 AM
Can not answer your question right now but will be pulling cowl for condition inspection soon and will check it out for you if no one else does before then.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 03-19-2016, 06:54 AM
Robert Anglin Robert Anglin is offline
Default Your fine.
[IMG][/IMG]
Most of us move that inside lower hole not on the baffle so much as on the flange of the cooler. I made a new lower hole up about 3/4 to one inch higher on that side so when it was driller to the baffle it would just clear the jugs fins. There is a spec. in most of the engine makers books to loose a few fins from breakage. Most builders don't like trimming a little off a fin, but if it is done well there is little effect to cooling if it is a small repair sight. On the subject of moving the cooler up a bit, yes we found that if you locate it up as high and out as you can, you can get a 9 row cooler to fit where the Van's 7 row is dawn-up to go by the plans. We have an ECI IOX-360 that the factory spec called out at 191 Bhp., but we worked on it a little and have it up about 2% from there. The 9 row cooler handles the extra heat load very well, even with all 8 oil spray nozzles installed. We found that 3/8" gap between the upper cowl and the top left corner of the cooler was all that was needed. I would do it anyway you like at this point, your on the right track with this one.
Hope this helps, Yours as always, R.E.A. III #80888
Old 03-19-2016, 06:59 AM
Default Your fine.
[IMG][/IMG]
Old 03-19-2016, 08:42 AM
Robert, thanks so much for the reply. Never thought about just raising the nutplate--duh! For the lower nutplate, I plan to use the existing upper rivet hole as the lower rivet hole for a miniature nutplate. This should result in raising the bolt hole by .6", this should be adequate to clear the fin. Thanks again!
Steve
Steve Riffe
RV-8
N23SR
Old 03-19-2016, 01:41 PM
SuperCubDriver SuperCubDriver is offline
Not long ago I installed a 9row cooler on my RV-8. I was only able to bolt the cooler with just one bolt on the inner (right) flange of the cooler. I made a brace to the lower part of the flange from this bolt to regain some rigidity. Didn?t have the idea to relocate the holes on the flange - good idea!
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
Old 03-21-2016, 04:33 PM
R. Daniels's Avatar
R. Daniels R. Daniels is offline
There's an easy solution for that problem. If you haven't found a good answer yet, give me a call one evening and I can explain to you how I've delt with the same issue on quite a few RV's.
Rex
530-396-2239
RV-8, flying since 2000, 1,020 hours TT
Have completed;
1 RV-8 My personal toy, IO-360, C/S, Tip tanks
3 RV-7A's
1 RV-4
1 Glastar
1 Velocity XL
1 Glastar under construction
1 RV-8 under construction
1967 Camaro RS undergoing frame off restomod
Pre-purchase inspections are my specialty
I cover everything west of the continental divide by RV-8
EAA Tech. Counseler. Chapter 157
Dues paid 2014-2015
Old 03-21-2016, 10:12 PM
Blain's Avatar
Rex
530-396-2239
Share it with the rest of us?
Blain
R-22 sold.
N82 Sierra Tango
