03-18-2016, 12:32 PM
LIO-360 on RV-4
Hi guys. I'm looking at an RV-4 that has the LIO-360 (reverse rotating), 200hp engine to buy. I've read mixed opinions about this engine for the -4. Some say the 200hp is not worth it for the added weight (about 40lbs?) compared to the parallel valve O-360. Others seem to be very happy with their 200hp angle valve engines in their -4's.
Anyone care to comment based on experience with either (or both) the 180 and 200hp engines? Besides the added weight, any other disadvantages of the IO-360 angle valve? What about fuel burn? Anything I should look out for in particular when deciding on my purchase?
Thanks!
Brian
03-18-2016, 01:19 PM
I have 200 HP parallel valve IO-360 and love the added vertical performance. 100 kts on take off produces 3,700 fpm solo, 80 kts buries the VSI at 4,000+. 25 squared gives me 192 kts at 3,500.
There is no substitute for horsepower.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
03-18-2016, 01:37 PM
Horsepower = fuel burn rate
Fuel burn rate is basically equivalent to horse power produced. A 200 HP engine running at 90% would get basically the same fuel economy as 180 HP engine at full power. The only difference is minor fuel efficiency differences between the two engines.
So the question is: are you going to keep the engine throttled down to have the same burn rate as the smaller engine?  Not me.
03-18-2016, 04:20 PM
The big question is the direction of rotation, especially if going constant speed, it seems the availability of props gets reduced. Also, if you are doing a hammerhead, it will be right rudder instead of left rudder just like the Sukhois.
Fuel burn is easily adjusted downward in cruise settings. At 9,500 ft I am burning 8 gallons an hour getting about 170 kts. (Appx. I don't remember the exact settings).
I'm still smiling from my last takeoff though.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
03-18-2016, 04:32 PM
Mike,
Just want to compare some numbers with you. I have 180 hp in mine. what are the units on the numbers below? Is the altitude in ft MSL, AGL, is that ft density altitude or pressure altitude? are the kts IAS or TAS? Thank you.
- 25 squared gives me 192 kts at 3,500
- At 9,500 ft I am burning 8 gallons an hour getting about 170 kts.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
03-18-2016, 05:32 PM
Just as a basis for comparison, at 9,500 MSL I can generally do 170KTAS at 8.5GPH in the Rocket.
The overall airframe drag is what dictates HP/fuel burn at speed.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
03-18-2016, 08:37 PM
Left hook...
Thanks!
Brian
Brian,
The LIO-360 in the Spitfire RV4 is a unique engine originally installed in twins to reduce P factor. There were several AD"s as I recall, all accessible on line. Make sure the crank AD has been complied with or its unaffected by serial number. As far as it being odd, I have quite a bit of M-14P (Sukhoi, Yak) time which spins "Left" as well. It only took one flight doing acro to get used to it. It should provide 170KTAS under 10GPH with the right prop and LOP.
My thought is if it's working and flying well, don't spend extra bucks for little gain. Counter-weighted crank IO-360's run smooth but are heavy. Bargaining chips for sure...
It could be a great airplane if the price is right.
V/R
Smokey
PS: In 2000 I converted a 0-320/wood prop powered RV4 to an angle valve IO-360/Hartzell. Added 92lbs to the EW, doubled rate of climb and takeoff fuel burn but also gained 12knots in cruise and equaled the old fuel burn at lower speeds. Still had a noticeably heavier nose (not as much as my HR2 solo!) and feel even with the battery in the baggage compartment. The lighter they are, the better they fly....
03-18-2016, 09:00 PM
Axel,
Altitude is msl, speed is true.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
03-19-2016, 09:13 AM
Originally Posted by Michael Henning
Axel,
Thanks Mike.
Brian,
a few comparison numbers for you since you asked about 180 vs 200 hp.
My plane:
-RV-4 air frame with fastback and rocket canopy
-sam james cowl and wheel pants
-engine plenum
-IOX-340 with electronic ignitions
-Full open throttle, leaned out rich of peak, 8500 ft msl gets me 189kts true (corrected/verified) burning about 9.5-9.6 gal/hr. I don't have all my fairings on yet and my horizontal stab angle of incidence is not where I want it yet. So I am hoping I can get to 190 KTAS after the changes.
-At my normal cruise (2650 rpm, fix pitch, cant remember MP), lean of peak, 8500 ft msl gets me 174kts true burning about 7.4-7.6 gal/hr.
That being said, all our air planes can't really be compared apples to apples. Some have electronic ignitions, some take painful approaches to reducing drag and drag cooling and some just build to plans.
Like Smokey said. If the motor is a good price, who cares. The only opinion that matters is yours. You can reduce some of the empty weight if you go to a fix pitch prop. If you go that route, pick a company that has experience making props for the pusher communities (i.e. Catto, etc).
Good luck.
Axel
03-19-2016, 11:22 PM
You might check with the RV 4 plans. Normally either the motor mount or Vertical stab is angled a few degrees to compensate for the prop rotation / p factor. If it is only the V stab alignment, that is easy to do. The motor mount, not so easy.
