Old 03-17-2016, 04:24 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tip: Priming tubes/weldments
Priming tubes.
Sometimes the bear gets you. Sometimes you get the bear. Today, I got the bear.
Almost every airplane has a tube or weldment and often they need to be primed inside. If you're like me, you struggle with sealing the end and inevitably more primer ends up on the floor than inside the tube. I've tried all sorts of plugs and tape with questionable results. My shop floor is evidence to my failure.
Most of us have a box of Nitrile gloves. Turns out they work for more than keeping your hands clean.
Cut the fingers off a glove or two. Choose the fingers that fit nice and snug. Pinky fingers work for smaller tubes. Thumbs work for large tubes. For this job, I used the middle fingers.
The gloves are usually dusted inside with powder to make them slide on easier. The powder will allow the finger to slide off.
Slip a finger over the tube but make sure the outside surface of the glove is the side against the surface of the tube.
Place the gloved end of the tube in a bucket. No reason to temp fate. Pour in the primer then slip another glove finger over the open end. Remember, inside out.
Slosh the primer back and forth while rotating the pipe. A minute or two or at least two rotations is plenty. Stand it on end over the bucket again. Slide the top finger off and pour the contents into a paint cup. Stand the pipe open end down in a bucket to catch the remaining primer and slip the finger off the sealed end.
No mess! Wish I had thought of this one several messes ago.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 03-17-2016, 06:34 PM
tgmillso tgmillso is offline
Nice one Larry. About to move onto prime a bunch of tubes because today I'll finally be wrapping up my fuel tanks (I was beginning to think this day would come). Your timing for this post is impeccable.
Cheers.
Tom.
Old 03-17-2016, 06:50 PM
AdamB AdamB is offline
How symbolic that the middle finger of the glove fit this particular job!
Looks like you showed it!
RV10 - #41687
http://adamsrv10.wordpress.com
N56AB Reserved
Old 03-17-2016, 06:59 PM
wirejock's Avatar
Default Funny
I wondered if anyone would notice.
Larry Larson
Estes Park, CO
Disclaimer
Old 03-18-2016, 07:17 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Default Primer is a tube
I have often wondered how effective it is to put primer inside a tube that is not properly cleaned ... how do you know that the primer will stick to the wall ??
I know a lot of people will have far more experience in this than I do .... but my understanding with respect to 4130 tubing .. in the good old days ... the welder would slosh the tube with Linseed oil ....
Today .. maybe something like Ardrox AV8 would be more appropriate ... Ardrox AV8 works for both steel and alu ... https://www.silmid.com/products/dina...ive-1lt-i.aspx
Just a thought ....
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 03-18-2016, 09:16 AM
JonJay's Avatar
JonJay JonJay is offline
Do the instructions call out priming inside the weldments like the rudder bar?
Obviously you can't prime inside the rudder stirrups as they are welded shut.
I know they call out priming for pushrods. Just curious.
As Jan points out, in the day, a hole was drilled, linseed oil was inserted and sloshed around and then the tube welded up.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-18-2016, 09:32 AM
wirejock's Avatar
Default Priming
Interesting question
No. There is no instruction for priming the inside of the rudder or flap weldments.
But, the fuse instructions are less detailed. I figured it wouldn't hurt.
As a side note, my idea is just a method for putting a liquid in the tube. Feel free to use whatever protectant you like. I actually sloshed lacquer thinner in them, let them dry over night then poured in SWP60G2.
Larry Larson
Estes Park, CO
Disclaimer
Old 03-18-2016, 12:00 PM
MElstien MElstien is offline
Default Alodine the tubes instead?
I am getting to that part on my build for the elevator push tube. Couldn't you alodine them or have the alodined? Is there a need for primer on the inside since once sealed up, there is no way to ruin the alodine protection. A dip would work on the outside as well and then prime the outside.
Just curious?
Michael
Builders Blog http://elstien.us/wordpress/
RV-10 Builder
Tail Kit delivered 6-2013
Finished QB wings on September 2018
Moved to Port Orange Florida November 2018
Tailcone mounted to Fuselage on 3-1-2020
Finished Fuselage April / May 2020
Working working working on Doors
Engine Ordered (BPA/Fly-EFII 8/1/2020
Dues Paid through 2020
Old 03-18-2016, 05:17 PM
wirejock's Avatar
Default Alodine
Just curious?
It's an aluminum tube so alodine would work fine. The only trick is prepping to alodine. You want to Alumiprep since it can't be scotch brite scuffed easiely. Then rinse and alodine.
I suppose if you had a PVC tube, you could use it to Alumiprep dip the tube then again to Alodine and both inside and outside would be done.
YMMV
Larry Larson
Estes Park, CO
Disclaimer
