Old 03-09-2016, 09:22 PM
wvshooter wvshooter is offline
Default Equiping for IFR
I recently read somewhere that a heated pitot tube is required for IFR flight. Then I read an EAA write up on equipment required for IFR which makes no mention of a heated pitot tube. Who's right?
Old 03-09-2016, 09:27 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
It's not a legal requirement, but it is a very good idea.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 03-09-2016, 10:53 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
It's not??????
Holy cow! Or Holy Pitot tube batman!!!
It certainly is down here, and we are not as "icing" as you guys up there.
David Brown
Old 03-09-2016, 10:57 PM
Different places, different rules. Canada requires two different types of nav receivers. Here in the US, there is a huge difference between the legal minimum and what mosts pilots feel is needed to operate at a reasonable level of safety.
Old 03-10-2016, 03:38 AM
Auburntsts's Avatar
In the US 91.205 spells out the equipment requirements for all phases of flight: VFR, Night, and IFR. And for those playing at home your OPLIMS will state the entire paragraph applies when equipping for IFR. And as previously stated a heated pitot is not a 91.205 requirement.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 03-10-2016, 05:23 AM
F1R F1R is offline
Several of the glass EFIS displays use attitude solutions that are pitot dependent. Several modes of most auto pilots are significantly impaired if you loose accurate pitot pressure. As mentioned previously, a heated pitot is a very good idea. Even if you don't plan on flight in IMC, one can find clear air that will produce ice.
Old 03-10-2016, 06:41 AM
MarkW's Avatar
MarkW MarkW is offline
The other side of that argument is that on most systems the pitot only provides air speed. Most will have ground speed with their GPS. A pitot can easily be done without.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 03-10-2016, 06:46 AM
dweyant dweyant is offline
How does clear air produce ice?
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 03-10-2016, 08:02 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Clear air does not. BUT I would never consider IFR without a working heated pitot tube.
I had one "where the **** did this half inch of ice come from" experience on a severe clear VFR on top day on my descent through the layer. I could not have hit the on switch for pitot heat fast enough. This is the same reason I back fitted a vacuum release check valve in the fuel tank vent lines.
Just put it in.
Carl
Old 03-10-2016, 09:00 AM
Carl
I agree you should (and I do) have a heated pitot, but there are plenty of valid reasons why, ice in clear weather is not one of them.
-Dan
Dan Weyant
RV-9A N96KD
