03-07-2016, 08:20 PM
Comm TX problem
I have a intermittent problem with a transmit problem on my comm radio. It is a off and on problem where it will transmit then a little later not transmit. When I can get it to tx I do notice that my panel mounted card compass moves and then when I stop transmitting it goes back to where it was. Any ideas?
David Herrmann
RV-7 N174DH built and sold
RV-8A N369DP purchased and flying/ Sold
RV-8 N3170L purchased and flying/ Sold
RV-3B N313RV purchased and flying Sold
RV-4 N488TW Flying  Sold
1946 J3Cub all stock and original flying Sold
1943 Meyers OTW-160  sold
1997 RV-4.5 N221TM wow, sold
03-07-2016, 08:33 PM
Does the "TX" indicator show up when you key the radio?
Is there anything between the mic/PTT and the radio (intercom). If so, what and what model.
What kind of radio?
Mike W
Venice, FL
N164WM
03-07-2016, 09:37 PM
Bendix/King
Yes when it is transmitting yes but then you push again and no transmit and no T showing. Push to talk in the top of the stick and radio mounted on the right side of the fuselage of my RV-3B. Bendix King KX Nav/Com .
What kind of radio?
David Herrmann
03-08-2016, 06:59 AM
Faulty PTT switch or connections?
Make absolutely certain that the radio is pushed fully into the mounting tray.
Joe Gores
RV-12 Flying
03-08-2016, 10:17 AM
Yep, sounds like something in the PTT circuit.
My dictum is that 80% of electrical problems are mechanical in nature, i.e. a loose connection, crimp, connector not fully seated, faulty switch, etc. The other 20% are also 80% mechanical!
Mike W
Venice, FL
N164WM
03-08-2016, 11:06 AM
My transmit problem
I recently had a transmit problem, probably not the same as yours, but found to be the headset wires. Fixed by Lightspeed, no charge.
03-08-2016, 03:44 PM
Same for me. Headset on the way to Lightspeed. It was intermittent for one flight and then died. Backup headset worked fine.
-John
John Banister
RV-8 Engine (IO-360), Prop (CS)
Flying Since Aug, 2011
2017 Dues Paid
03-08-2016, 04:50 PM
Headset
Headset was ruled out by trying another one with the same results.
Thanks everyone for their input .
David Herrmann
