03-07-2016, 12:27 AM
Aileron response
Hi,
I fly my RV 8 since a Few days , just 3 Hours, and I am quite surprised by roll response...at 150 kts or above it's hard to get a slow bank.
Can I change something in The controls? Waiting for a response from Van's.
rv8
First flight february 11 th 2016 , delightfull....
03-07-2016, 04:58 AM
Just learning to fly my -4. Thats just the way they are. I was taught to use two fingers on the stick during my transition training. In my mind I was barely moving the stick, but the plane was making drastic changes in pitch and bank. They are touchy by design.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
03-07-2016, 05:03 AM
It is a 2 finger operation, in time you will relax a bit and it becomes second nature.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
03-07-2016, 05:48 AM
Trackdom,
My suggestion is to leave the ailerons the way they are. In 50 hours you will learn to appreciate the roll response and love it. Fly it with two fingers now as others have said.
Jerry Esquenazi
RV-8 N84JE. 1100 hours
03-07-2016, 06:55 AM
They will indeed seem twitchy when transitioning from something else, but yes, they can be tuned for less sensitivity. Trailing edge shape has a large effect.
Mine (QB ailerons) were way more sensitive than I preferred, but some trailing edge squeezing fixed it...light in the lower end of the speed range, firmer at higher speeds.
Dan Horton
RV-8 SS
Barrett IO-390
03-07-2016, 07:05 AM
Touchy Ailerons
Like everyone is saying RVs are very light on the controls. I wouldn't touch a thing, love the response of my 4. You will get use to the handling and will become second nature to you.
Brian Eisner
RV-4 C-GRJT
Bedford Nova Scotia
Canada
Dues paid for 2019
03-07-2016, 07:36 AM
Sad to admit but I flew in my first RV this weekend and happened to be a 10. Didn't takeoff or land but was able to do some maneuvering from the right seat for about 20 mins. I was amazed at how sensitive the stick was, as others mentioned I just used two fingers and got used to it fairly quick.
03-07-2016, 08:04 AM
Yes, RVs have outstanding aileron response. However, it's worthwhile to be sure the ailerons were built correctly. Here is an article about my experience with my RV-7:
http://www.mnwing.org/building-tips/twitchy-ailerons/
Doug Weiler
Hudson, WI
president, Twin Cities RV Builders Group
RV-4, sold
RV-7 completed and flying N722DW, 840 hours
Based Lake Elmo, MN (21D)
03-07-2016, 08:21 AM
Originally Posted by dougweil
My only experience so far is with the trim tabs, I built them so only have myself to blame but there were a bit too 'rounded' so I did essentially what you did and squeezed them more flat. I also ended up with some concaveness but nothing too bad. In a few years I guess I'll find out how it flies.
03-07-2016, 09:03 AM
The comments about aileron trailing edge making a difference are spot on (rounded means lighter; sharper edged means heavier). Note that the RV-9 (heavier controls) has wedge shaped inserts in the trailing edges instead of the 'folded' trailing edges on the other 2 seat RV's.
But, the planes aren't twitchy, even with rounded trailing edges. It's all about what you've calibrated your hands and arms to expect. For example, few Cessna pilots complain about a 182's handling, but to me, they feel like the controls are binding all the time. If you don't re-trim for landing, it takes both hands (and a reasonably strong back) to flair. :-)
Here's a tip to compensate until you recalibrate your touch. Ignore your stick grip and slide your hand down the stick 4 - 6 inches (sorry; 10-15 cm). You won't move your hand as far, but pressure will go up; closer to what you're probably used to feeling. Another benefit is that you can rest your forearm on your leg, and use that as a stabilizer. Then you can use your wrist and fingers for control, instead of your arm strength. This will give another perceived increase in stick force. I find it more comfortable, and do most of my flying this way, except during t/o, landing, and 'high energy' maneuvering like acro.
FWIW...
Charlie
