Originally Posted by RV6_flyer
Unaware of a change in aileron and flap skins.
Yes Elevators skins were changed on ones that had 180 HP engines as cracks were developing in the elevator skins on the airplanes with larger engines.
Well, that was a prevalent theory back in the day that turned out not to be true.
Lot's of us out there with 180HP and .016 skins in both RV4's and RV6's doing just fine....
The assumption of the day is cracks develop from preload as a result of poor fabrication techniques. This had become a well known issue by the time I built mine and if you follow the plans, it is very unlikely they will crack even if you have a 180HP engine..... 700 hours on mine, and I am sure they will start cracking tomorrow as a result of me writing this !
