Old 02-12-2007, 08:05 PM
walter's Avatar
walter walter is offline
I used to worry about that too. I tried putting electrical tape on the head, that works for a few rivets. Then I polished the head every 20 rivets or so with metal polish, which worked pretty well, but was a hastle.
What a waste. Now that I'm ready for paint and I know what theyare going to do to the bare aluminum (sand it!) I would not worry about it unless you intend to have polished aluminum surfaces.
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 02-12-2007, 08:08 PM
lucky333's Avatar
lucky333 lucky333 is offline
Default Polish the face of the set with this..
.. guy I know did it and gets mirrors every time. The other posts are valid, it doesn't matter but he was pretty jazzed at the results he got anyway.
METALL
John
John Oldenkamp
RV-7A project for sale
VAF Paid 2018
RScott RScott is offline
FWIW, I use electrical tape. Cheap, readily available, the glue doesn't dry up & stick the way masking tape does. It does often leave a little black dot on the rivet that comes off easily.
Dick Scott
RV-9A wings, working on flaps
Old 02-12-2007, 08:43 PM
briand's Avatar
briand briand is offline
The scuffs bothered me too so I use the clear packing tape. It lasts a while. I may not paint and it looks good up til then even if I do paint.
Old 02-13-2007, 03:53 PM
ctbecker ctbecker is offline
I've always done what Mike suggested. 1 or 2 layers of 2" masking tape on the set and cut out around the edge. Usually last two or three nights. No marks.
Charlie Becker
N464CB. RV8A(es)
Certificate Issued
Old 02-13-2007, 06:44 PM
cytoxin's Avatar
cytoxin cytoxin is offline
Default notice the rib line?
i found this to be caused from the shooter pushing to hard on the gun and the set not being centered after the first hit due to the flexing of the rib flange. when this happens it folds the rib some and concentrates the pressure on the web of the rib. my helper wanted to do this some and i had to beat him about the head and shoulders. if you can see the skin deflect much more than a touch when they apply pressure, then IMHO they are pushing to hard.
William Weesner/ still kicking.
Old 02-14-2007, 08:51 AM
GAHco's Avatar
GAHco GAHco is offline
Post Correct Tape #
Originally Posted by GAHco
Use Scotch 847 magic removable tape in either 1/2 or 3/4 wide.
Put the rivets in, put the tape over it, rivet, and remove the tape.
You can use short strips and use them several times.
Cheap and easy, but looks classy when your done.
Sorry it's #811 NOT 847, We used to stock it but people complained that they could have gotten from the stationary store. and they still can.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 02-16-2007, 09:18 PM
ruggedgeolife ruggedgeolife is offline
Default flush rivet set problems
Hi, that super thin pure aluminum coating on the alloy is very soft and delicate. You can mar it by just rubbing your finger hard on it. (trust me, I know p )No matter what I do, I get a slight amount of scuffing reguardless of my mirror finish flush set. But it is a very minor thing to me. One must hold a light on the scuffing to see it clearly and it's only around the rivet head. I don't use the rubber collar. I figure that any scuffing of that thin 'alclad' isn't going to show through the paint job. To me, the 'alclad' coating is only for corrosion control during construction. If it scratches, I rub out the scratches with the scotchbrite and destroy the 'alclad' in the process, oh well, it gets primed very soon anyway. I hope my experience helps.
Fritz
