  #11
Old 02-27-2016, 08:27 PM
PIN 37 PIN 37 is offline
Yes Steve, I would be worried about damaging the close tolerance bolt holes as well, I might try making a bucking bar, I do have access to some quite sophisticated machinery,and then tap from the bottom with a male die.
Phil
LAME (Aust)
RV7 99% finished
Old 02-27-2016, 09:09 PM
YellowJacket RV9 YellowJacket RV9 is offline
I forgot to dimple the #8 holes for the rear fuselage inspection panel screws and was unable to get my squeezer in there with the longerons installed. I cleaned the skin and then put a drop of oil over the holes, and screwed a #8 screw into the already installed nutplates, after testing on some scrap. It made very nice dimples, even after inspection with a magnifying glass. Your results may vary of course...
Chris
Chris Johnson
Old 02-27-2016, 09:31 PM
7DeltaLima 7DeltaLima is offline
Default Pop Rivet Dimple dies?
Not sure of the exact location but have you looked at the pop rivet dimple dies? Just a thought...
Doug
RV-7A N277DL flying 4-15-2004
RV10 N277CK flying 5-28-2010
www.oncloud7.com
Old 02-28-2016, 12:37 AM
Yeah Doug, have thought of that, but not an option unfortunately.
Phil
LAME (Aust)
RV7 99% finished
Old 02-28-2016, 12:42 AM
KRviator's Avatar
KRviator KRviator is offline
Is it really the end of the world If you don't install countersunk screws there? If you really don't want to try any of the (quite good) aforementioned suggestions, you could install either pan-head or AN525 washer-head screws there and wear the 0.05MPH loss in speed. You're the only one who'll know they're not supposed to be there!
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 02-28-2016, 04:34 AM
MeAndMyToys MeAndMyToys is offline
Default structural?
I think I remember that interface is structural in shear, those counter sinks would add to the shear strength. I would contact Vans before committing to anything on those.
N17BJ
RV-7 Tip Up slow build
200HP IO-360-A1B
Hartzell CS
Working on wiring and Fw Fwd
Got my RV-7 tail kit for X-mas 2012
Guess the Wife's on board!!
Dues paid 3/11/2019
Old 02-28-2016, 06:33 AM
Taildrgr's Avatar
Taildrgr Taildrgr is offline
Use this:
http://www.cleavelandtool.com/8-SCRE.../#.VtL2w5X2aUk
The die won't rotate and spall the skin.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 02-28-2016, 06:52 AM
Mel's Avatar
Mel Mel is offline
Originally Posted by Taildrgr View Post
Use this:
^^^THIS^^^ is the answer. I use "pop" rivet dimpling pretty much exclusively.
I have several tools similar to these that I made years before they were commercially available. The only difference between these and mine is that I tapped the female die so you don't have to use a back-up nut.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-28-2016, 06:59 AM
Originally Posted by rv7charlie View Post
I'll try to measure for you when I go down to the hangar in the morning. Do y'all have the equivalent of Harbor Freight Tools down under? You can get 'good enough' digital calipers for less than $20 US; often much less. Old style dial are often under $10.
But I seriously doubt it will be an issue, even if they're .040.
According to my Harbor Freight calipers, the fuselage belly skin is .025" & the wing bottom skin is .032".
If you're building a show plane, the Cleveland die would help make a perfectly edged dimple. But you should be able to come pretty close with just a screw.
For something 'in between' in quality and a lot quicker to get, you could drill & dimple a 1" disc of .040", & use that as your die under the head of the screw. Just whack the daylights out of it in your C-frame to be sure you get a good sharp edged dimple on the homemade 'die'.
Charlie
Old 02-28-2016, 11:29 AM
Billythekid Billythekid is offline
I can't wait to make it these mistakes. It's only the ability to reason that wears so thin. There something to be said for doing something the second time...or third. I read these mistakes and it makes me laugh cause I know there is a day or 50 when vans universe is laughing at me.
