Old 02-25-2016, 02:20 AM
AusFlyingBear AusFlyingBear is offline
Default Alodine and Alumiprep
Hello all,
I'm practising with alumiprep and alodine as that's what I intend to do on my RV14A rather than Priming.
Not sure if I'm doing it correctly though. The following link is to my Vans Tool Box kit and images of how it turned out with Alodine.
http://www.rv-14a.net/blog/another-practice-project
Would be great to hear some hints or tips as to whether I'm doing it correctly or if I need to do.
Thanks in advance.
Ian
--Now permanently working in Christchurch New Zealand----
Christchurch, New Zealand
Building an RV-14A - No. 140239
EAA - #1130849
www.RV-14A.net
www.facebook.com/iansrv14a
Old 02-25-2016, 06:00 AM
daveyator daveyator is offline
Clean off the red mill stamping with MEK, or some other solvent. Alodine finish will be damaged during assembly. If you feel you must go down this path, use it as a base for primer, not as a final finish.
Just my opinion.
DaveH
BTW, I'd get rid of that claw hammer asap. It's a wood butchers tool. Has no place in a metal workshop
Old 02-25-2016, 06:01 AM
BillL BillL is offline
Hi Ian,
Through some experimentation of my own, it appears to be a cleanliness issue.
I dip my parts, so let's start with that. I clean the parts with mineral spirits to get sticky stuff, and then wipe with a wet towel of alcohol. Denatured or rubbing (ethyl or isopropyl) all over. On small parts without label adhesive, acetone works too. I just don't like the smell. Dip in prep solution for 2-3 minutes, rinse in distilled water (sometimes just spray down small parts with hand sprayer), then dip in alodine for 2 1/2 minutes - or longer if weak to match colors. Rinse in new water, blow dry with shop air and hang for 24 hrs. That cured my mottling. Try these on your own for a starter.
Any other cleaning process you want to ask about - I probably tried it. Many worked but this seemed to must efficient and I stopped experimenting. Plastic buckets, 3" PVC tubes (vertical), and large plastic storage containers have been used.
Last thing - I had some corroded 2024 .063 and it looked pretty bad. It needed some scotchbrite to level the surface, then the other steps left a nice finish.
Bill
RV-7
Lord Kelvin:
Old 02-25-2016, 06:58 AM
fixnflyguy fixnflyguy is offline
Default "The process"
So,
Not to start a "pre-primer" war, and following the process used by virtually all the major aircraft manufacture and repair process, (my day job), I will put into laymans terms the basics.
The aluminum as delivered is either "Alclad" ( most all sheet stock), or "bare", (most all extrusions). During the finish process of painting, the aluminum needs a good cleaning, either mechanical (Scothbrite,ect.) or chemical (Alumiprep,ect.). After cleaning, the Alodine is applied as controlled acid etch which seals and promotes adhesion for the yet to be applied primer/paint. Some people choose to eliminate priming, and directly apply the paint topcoat, which I personally don't recommend. Its hard to beat a light coat of epoxy primer that is compatable with your topcoat system...others may have their opinion.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 02-25-2016, 08:38 AM
rvbuilder2002's Avatar
I was assuming the OP meant bypassing priming for all interior substructure?
Not priming the exterior with a primer recommended for the paint being used is a very bad idea. The primer is an adhesion promoter. Today's paints don't adhere well without an appropriate substrate (primer) that it can cross link too.
Scott McDaniels
Hubbard, Oregon
Old 02-25-2016, 12:45 PM
Can you explain 'alodine applied as a controlled acid etch'? I thought the alumiprep was the acid etch, and the alodine was the conversion coating.
I agree with others that you probably have a cleaning issue. When I started my project, someone with a lot of experience told me to clean (degrease, mainly), rinse with *clean* water, acid etch, rinse with clean water, alodine, rinse with clean water. Using distilled water to rinse is best, but might cost more than the chemicals. :-)
FWIW, the best cleaning technique I've found is to wipe any ink off with solvent, scuff with scotchbrite, & load the parts into a dishwasher, if they will fit. Run them through a full cycle using a good dishwasher detergent (excellent degreaser). Go straight from the dishwasher (using clean gloves) to the acid etch, and then through the rest of the steps.
Your wife will never know....
Charlie
Old 02-25-2016, 05:05 PM
Pat Stewart Pat Stewart is offline
So,
Absolutely spot on Bill. I would not eliminate the primer.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 02-25-2016, 06:30 PM
6 Gun 6 Gun is offline
Smile prime
You could clean and use self etch primer.
Bob
Old 02-26-2016, 05:25 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
One point here ... If you use Alodine - then do not use a etch primer .. use epoxy primer ... Etch primer (typical very light coat, almost translucent) to be applied on surface that has no other coating ... so it can etch into the metal ...
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 02-26-2016, 05:42 AM
Default Show me your data report, I'll show you mine.
Bob
Where is your data that a self etch primer provides corrosion protection for 2024 in a salt spray booth with a scratch test.
Bill
RV-7
Lord Kelvin:
