Old 02-21-2016, 06:46 AM
StuBob StuBob is offline
Unhappy Tight Quarters - E-703
This has been discussed before, but there's no consensus and a lot of photos have fallen off. I've emailed Mike Lauritsen to see if there's a tool I don't have, but thought I'd get input from the rest of the Brain Trust.
I'm having a hard time setting the rivets at the aft ends of the elevators. The worst one is on the top side of E-703, the outboard rib. At that spot, I measure the vertical clearance at 0.35". Subtract from that the pre-setting length of the rivet (9/64 = 0.14") and you wind up with 0.21". I ground down the end of my no-hole yoke as much as I dared, and it's still way too thick. I've tried various bucking bars and made a stab at "indirect" riveting, but everything small enough to fit is too light to buck. Is there really something that'll work in an area where the clearance is two tenths of a stinkin' inch?????!!!!
I finally put a pop rivet in there but I don't like it, especially on the top where it's visible.
What are the options I've missed?
Stu F.
RV8
Old 02-21-2016, 08:07 AM
wirejock's Avatar
wirejock wirejock is offline
Default Rivet
Doesn't sound like you've missed anything. If you have a really tough screw driver, place the flat side on the shank and drive as close to the skin as you can.
Nothing wrong with the pop rivet. Plans sbow them i those areas. Once painted, no one will know.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-21-2016, 08:26 AM
SledDog SledDog is offline
Default Offset Rivet Technique Link
Here's a link that will demonstrate how to set these rivets. I used this and it worked well. http://www.eaavideo.org/video.aspx?v=5337092001
Roger Grahl
Lac du Flambeau, WI
RV-9A Slider
Empennage - Completed
Wings - Completed
Fuselage - Completed
Finish Kit - Under Construction
VAF donation through October 2020
