Old 02-20-2016, 04:23 PM
DragonflyAero DragonflyAero is offline
Default Where to measure voltage
Where is the best place to measure voltage, or does it matter?
Thanks!
Bill Vinson
RV-7 Standard Build
http://www.mykitlog.com/users/index....r&project=2226
Old 02-20-2016, 07:30 PM
cderk's Avatar
cderk cderk is offline
The best place to measure voltage for what???
This is a pretty vague question.
RV10
http://n688cd.wordpress.com
Old 02-20-2016, 09:03 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
If you measure bus voltage, that may not give you accurate battery voltage before you start. I wish mine was wired to let you measure either.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 02-21-2016, 06:30 AM
Sorry for being vague. I am using Dynon Skyview and wanted to know where I should attach the wire that provides the voltmeter reading. I can easily tie into a buss from the VP-X inside the cockpit, or do I need to go back to the engine side of the firewall and connect to the battery or somewhere else? I would think voltage would be the same as long as it is being picked up on the positive side of any device.
Bill Vinson
RV-7 Standard Build
Old 02-21-2016, 07:28 AM
Carl Froehlich's Avatar
I offer you may be over thinking this.
Voltage is an excellent measurement for the health of your electrical system. As example, a loss of alternator will immediately be reflected in a signification buss voltage drop.
You will, under some circumstances, get slightly different voltage readings depending on where you measure. The obvious example is the voltage at the battery will be higher than the voltage at the starter when cranking the engine. But - when not cranking the engine the current draw from the battery will not be large enough to make a meaningful difference in voltage between these two points.
Bottom line - connect to a convenient spot on your main buss. This way you are monitoring your panel voltage, and all the elements in play to get the panel that power (battery, alternator, master solenoid, etc.). Whatever small difference in voltage between these elements is not relevant to why you are monitoring system voltage.
Carl
Old 02-21-2016, 07:59 AM
Excellent. Thanks Carl!!!
Bill Vinson
RV-7 Standard Build
Old 02-21-2016, 12:02 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Dynon reads about 0.5 volts low
My Dynon EMS 120 reads the buss voltage about a half volt low, consistently. I have verified this several times with appropriate meters. It is no big deal, and I allow for it in my "tolerance" level.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 02-21-2016, 12:33 PM
RV6_flyer's Avatar
Ron
My EMS D10 also is exactly 0.4 Volts low. Dynon replaced the 1st unit I had under warrantee. The 1st unit would read correctly but the replacement is 0.4 Volts low.
If only there were a user calibration adjust point or menu that the user could calibrate and adjust errors out.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-21-2016, 07:10 PM
erich weaver's Avatar
Not a Dynon expert but my understanding on the GRT units is that they read about 1/2 volt low because of an internal diode to stop power from ever flowing backwards out of the unit (from a secondary power input outthrough the primary power input). The diode results in the loss of about 0.5 volts. Maybe same deal in Dynon?
Erich
Old 02-21-2016, 08:30 PM
airguy's Avatar
airguy airguy is offline
Most of us with full monitoring want to also check the amps flowing in/out of the battery with a shunt device, which takes two wires (upstream and downstream of the shunt) to measure the amps flowing through the shunt. You can use the battery side of the shunt to also measure your battery voltage. The Dynon EMS does not automatically do this (though I think it really should) so you'll need to split that sampling point to two different pins on the EMS connection.
