02-08-2016, 06:44 AM
AeroLED Trouble Shooting
So my left NS90 is acting up. Here's the symptoms:
- Strobe on - weak flash and flash pattern not sync'd with right wing or tail.
- Nav on - weak or no Red position LED
- Both Nav and Strobe on - the Red position LED strobes and the White Strobe is weak and intermittent
I've got 98 hours on the system to date and fly with the strobes on all of the time. To this point it's worked flawlessly. So before I go yanking off the wingtip or potentially the cabin flap torque tube cover panel (where the wiring for the wingtips and tail splice together) anybody got any suggestions as to where I should focus my initial efforts and what the potential issue is? I'm thinking the culprit is a grounding issue. My next guess, if the gorund proves OK, is a failed unit.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
02-08-2016, 11:19 AM
The vast majority of electrical problems are caused by bad connections. It is easier to find those bad connections when the circuit is fully loaded. I like to use an automotive lamp to load the circuit while using a voltmeter to find voltage drops (bad connections).
Joe Gores
RV-12 Flying
02-08-2016, 11:25 AM
Todd,
I'm sharing the obvious. Give AeroLED a call. They've been extremely helpful in the past, plus nobody else will be familiar with the stereotypical symptoms than them. Dean has always willing to go the extra mile to assist a customer.
bob
02-08-2016, 11:33 AM
Oh I know and I plan to give Dean a call soon unless he posts something first. One of the intents behind my post is to create a VAF record of my issue in case someone has a similar problem in the future.
PP ASEL-IA
WAR EAGLE!
02-08-2016, 12:29 PM
I agree with you, pull the wingtip and check ground, then the flap panel to check those connections.
What kind of splices did you use? Solder or crimp?
I am interested in hearing the fix since I too have those units.
John Mastro
RV-8
02-08-2016, 01:22 PM
The nav and strobe circuits share a common ground. For both functions to be having a problem like this, the most likely cause is a resistive ground connection, which could be a bad crimp or a dirty or pushed pin connection in the connector, or a bad connection to the aircraft ground. If in doubt, remove the light and bench test it using a 12 V battery. Make sure that the ground pin in the connector isn't dirty. If you want to bypass the connector you can use metal pins to poke through the insulation on the wires themselves to get to the conductors for a direct to wire test.
02-09-2016, 06:02 AM
Thanks for posting
Thanks for posting this, Todd. I am having the same issue with the tail light. Very weak strobe and no white. Yesterday I removed the rudder bottom, cut off the connectors and installed new ones and now nothing lights up!  on my way to the airport today to try to resolve that issue. Thanks, Dean, for the input as well. Love my AeroLeds.
RVRC
Robert Cutter
RC & Moonpie
RV7 slider - First flight 5/3/14
Over 500 hours on the Hobbs now
N516RC
02-20-2016, 04:14 PM
Epilogue. ..
So I finally got back out to the hangar to pull the wingtip and trouble shoot. Turns out I had a couple of problems: 2 pins on the molex connector weren't seating properly and there was also a nut on the mounting bracket (that was also a ground point) that was loose. The molex was giving me fits so I replaced it with a D-sub and tightened the nut and that solved my problem.
PP ASEL-IA
WAR EAGLE!
02-20-2016, 05:12 PM
I also found my problem
We also had a bad molex connection. Replaced with D-sub pins and small heatshrink. Second problems was the main ground wire had a bad crimp in the terminal end. We didn't use the whole D-sub as ours was in the rudder bottom for the tail light/stobe and would not fit through the hole to remove it if needed. I now have a service loop long enough to pull the light off and get to the connectors without removing the rudder bottom.
RVRC
Robert Cutter
RC & Moonpie
N516RC
02-21-2016, 06:21 AM
Dsub pin amp capacity
A question for the experts:
What is the current capacity of a standard Dsub pin like the ones that Stein sells?
I used molex connectors for my Aeroled Pulsar NS and Aerosun VX lights because of the 5 amp each max draw and 18 Ga wire.
I'd like to change to Dsub pins if they can handle the 5 amp current.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
