  #11
Old 02-11-2016, 03:07 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Originally Posted by Av8torTom View Post
Thanks, can it be purchased locally? Auto store? Hardware store?
There's a Permatex version of 567 that you should be able to find a cross-reference table for in order to identify the exact number.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-11-2016, 07:39 PM
Av8torTom's Avatar
Anyone have any experience with a Loctite 567 alternative that I can buy locally?
N677AT reserved
Superior XP O-320, 160HP
Old 02-11-2016, 07:57 PM
Carl Froehlich's Avatar
Napa, Advanced Auto and similar places have this under one name or another.
Old 02-11-2016, 08:42 PM
From the Parker site (manufacturer of our wheels), suggests permatex 56750 is an equivalent to Loctite 567.
http://www.parker.com/literature/O-R...RD5796rev2.pdf
Steve M.
Ellensburg WA
Old 02-12-2016, 06:40 AM
BillL BillL is offline
Default Warning!
... and tighten the heck out of it.
Not with 567! There is a torque spec for this (not handy at the moment) then turn until aligned. This is slippery stuff.
I was very careful about this when installing the oil cooler fitting in the engine case. It won't get as tight as you think, based on plumbing experience. AND . . . this is a 1/8" NPT fitting.
Funny story, my Dad frequently worked on equipment (off road) and is line was "tighten it until it squeaks" . I had some guys who did that with a 3/4" air impact on some wheel nuts on an articulated truck. The wheel fell off! The 3/4" impact only went to 250 ft-lbs (longer story), and the nuts needed 360 ft-lbs. Lesson - never assume.
Bill
RV-7
Lord Kelvin:
Old 02-12-2016, 07:09 AM
Walt's Avatar
Walt Walt is offline
Any chance we could get a picture of you torqueing those master cyl fittings to "spec" on a completed aircraft
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-12-2016, 08:08 AM
Av8torTom's Avatar
Thanks all... whoda-thunk it could get this complicated...
Seriously, I really appreciate everyone's suggestions.
Tom
N677AT reserved
Old 02-12-2016, 11:00 AM
gasman gasman is offline
I'm running my brake lines - in particular the brass elbows that screw into the brake cylinders. Do these get any sort is sealant on the threads?
Tom
Measure the depth of the tapped hole and tape the measurement on the fitting so you can see if the fitting is going to bottom out. You might need to file the fitting.
This size fitting should not require EXCESSIVE force.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 02-12-2016, 01:52 PM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Tom
The more people you ask .. generally the more complicated things get
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 02-12-2016, 02:34 PM
sibriggs sibriggs is offline
Default Teflon Paste
One of the major reasons for not using Teflon tape is that it may brake off and clog a opening in an aircraft line. Similar to what might happen with Fuel Lube. But why wouldn't a gob of any thread paste pushed into the end of a fitting do the same thing? Can't see the difference in using Teflon tape or Teflon paste.
Steve Briggs. RV9, G3x, G5, VPX, GTN625, PMags, A&P, IA, ATP-CFII
